Disable Alarm
nguyen
I had a starter installed in my vehicle. Everytime I remote start the car, the alarm goes off. When I insert the key into the door, the alarm stops and the car starts. I need to disable the alarm so I can remote start the car.
Did the remote start come with its own alarm...
Did you have it professionally installed...
The place that installed the remote start really should have bypassed the factory system.
that is what happen when jackasses try and play with luxury toys in buisness.
If the installer was up to par on the cars he worked on he would have had it working properly . Like most peoples ,mine also ,remote start easily and the aftermarket alarm works with the oem one. I can arm both if i want.
  • 19 years later...
Did you try rotating the steering wheel, left and right while trying to rotate the ignition key? If you were to inadvertently rotate the steering wheel and cause it to lock, what you describe would happen.
