zeus87gn Posted October 14, 2008 Share Posted October 14, 2008 Ok, Ive replaced the mast and drive stem on the power antenna but I don't think it's right. It goes down just fine. When it goes up, it gets to the top and makes this buzzing noise and then drops back down a few inches. I'm guessing it's skipping on the teeth because it doesn't know where to stop? The instruction sheet that came with the replacement mast states it will stop in a few turns of the radio by self adjusting. It's been doing it for a couple of weeks now. Have I done something wrong? Have I not done something? Any and all input is welcome. I'm hoping someone has run into this and has a solution. Thanks in advance, Z Quote Link to comment Share on other sites More sharing options...
mdb3sgte Posted October 15, 2008 Share Posted October 15, 2008 I don't really have a solution for your problem, but i'm having an interesting problem with my stock antenna. Everytime i change to a different station the antanna goes down about an inch or so then goes back up. Any ideas why it would be doing this??? Quote Link to comment Share on other sites More sharing options...
zeus87gn Posted October 15, 2008 Author Share Posted October 15, 2008 Wow, that is weird. You thingk WD-40 will fix it? Where's the Lexus guru who knows everything? Quote Link to comment Share on other sites More sharing options...
zeus87gn Posted October 21, 2008 Author Share Posted October 21, 2008 Anyone? Anyone? Bueller? Quote Link to comment Share on other sites More sharing options...
UCF3 Posted October 24, 2008 Share Posted October 24, 2008 Is this a stock antenna mask or an aftermarket? I know the stock mask will go up an additional 2" and then will drop back. The buzzing or grinding noise might be due timing of when the teeth catch's the sprockets. If you still can, try to remove the mask and install it again. Who gave you this idea of using WD40? Didn't you say it was a new mask? Quote Link to comment Share on other sites More sharing options...
zeus87gn Posted October 24, 2008 Author Share Posted October 24, 2008 Thanks again for the response. It appears to me to be the original antenna. It is stamped Toyota and plugged into the the fcty wiring harness. It's quite obvious the grinding noise the the gear on the teeth. It's try removing and reinstalling and see what happens. Would it matter that I had to remove the entire antenna and break the case open to remove the old broken stem? The WD40 thing is a joke. There's another thread on it bing the wonder fluid here in this section. Quote Link to comment Share on other sites More sharing options...
UCF3 Posted October 24, 2008 Share Posted October 24, 2008 Thanks again for the response.It appears to me to be the original antenna. It is stamped Toyota and plugged into the the fcty wiring harness. It's quite obvious the grinding noise the the gear on the teeth. It's try removing and reinstalling and see what happens. Would it matter that I had to remove the entire antenna and break the case open to remove the old broken stem? The WD40 thing is a joke. There's another thread on it bing the wonder fluid here in this section. On my old Infiniti I bought a new mask/teeth cable, and let it catch the motor, but I haven't tried it on my old LS or SC yet. I've just replaced the unit and installed a new one-but the motor was gone so i had to. You could try to open it up, and adjust it, but my solutions are generally to bite the cost and replace the unit, if it's annoying. Oh, I finally came across that Thread you were referring to about the WD40. Wow!!! Quote Link to comment Share on other sites More sharing options...
jbarhorst2 Posted October 25, 2008 Share Posted October 25, 2008 The antenna will adjust it's length to tune in the radio station you have selected the best that it can. As far as the grinding, it sounds like the stop set points are not working. I'm not sure if these are switch related or programming related. Tom Quote Link to comment Share on other sites More sharing options...
