I have heard that the SC300/400 comes stock with forged pistons. Now I can't remember where I heard this or I'm thinkin I might could have dreamed it, I dont know. So that's why I decided to ask ya'll. Any replies are appreciated. Thanks!
I haven't heard that before. Since the SCs are using one of the Toyota Supra engines, it's possible that you can get forged pistons.
From what I deal with, they all list the Pistons for the GTE, which since the block is the same from what I undersand, they SHOULD still work.. someone correct me if I'm wrong on that.. Not sure about head clerances though..
Weisco 8.25:1 Compressin
CP Forged 8.5:1 Compression
JE/SRP 8.5:1 Compression
That's what I have listed without digging too deep.
The factory OEM pistons are indeed forged and resin coated. I know this as fact in the 2jz-ge inline six from 1992 to 1997. Anything above and beyond that, I'm not sure on. But think they are forged pistons into the the last model year. There is a performance specs. thread pinned up there that has all the details of the 1993 SC300 that basically holds true across all model years with the exception of a few body style que changes, creature comfort option addtions, and the introduction of vvt-i in 1998. Here is an excerpt:
225 hp
forged steel crank - held by seven main bearings
a two piece oil sump that actually adds rigidity
Acoustic control induction system (ACIS) varies the length of intake runners - long at low revs and short at high
5 speed manual or 4 speed auto with ECT
10.0:1 compression ratio
High strength hot forged connecting rods with oil jets
Resin coated pistions - large valve diameter
1.23 hp per cubic inch
Sorry to inform you. I have opened up few 1UZFE (SC400). The pistons are NOT Forged. They are casted with special coating. I am not sure about SC300 and 2JZGTE motor.
