once i start the enging or just turn the key one step i start hearing a drilling sound behind the climate control panel or the stereo which last for arounf 30 seconds then it disappears.
You're probably just hearing your master cylinder although it could be anything, does it happen right after you press the brakes to put the car into gear?
That is your speed sensitive front suspension activating. ;)
Thanks for your reply. The sound starts once I turn the key (switch) one step before the engine starts.
That is correct sir ;)
  • 1 month later...
