Help, How Can I Remove Hub Rings?
Ralow
I am trying to put my OEM wheels back on for the winter but I can't get the hub rings off! Anyone know a trick to remove them without having to cut them off? I have the aluminum ones and I think they are rusted on...I knew I should have got the plastic ones!
I am not sure ,but have you tried to remove the center cap of the rim and tap it off back wards with a large 19mm or larger socket and a hammer?
The ring doesn't get stuck on the wheel it gets stuck on the hub. Small chisel works very easily.
