93 Ls400 - Should I Buy, Or Not?
Anwisok
I have an opportunity to buy a 93 LS400 with 183 k miles on it for $2700. This was basically a one-family car, has full records to 90k, and I can contact the previous owner with specific questions (like, was the timing belt changed when it came due the second time around).
The current owner, a friend of mine, bought it for even less, with the intention of turning a profit, and knows the original family personally.
Overall, the car is in VERY good shape, with a few minor issues which simply add character and can be addressed as time and budget permit. It does, however, have one (possibly two, but they may be related) issue/s which concern/s me.
The car has an issue with the instrument cluster which I have not seen directly addressed, and I wonder if anyone can give any guidance on this specific issue.
The car has the fading speedo needle, which I have seen addressed numerous times. I also has an issue where the instrument cluster is simply dead when cold. Unless the car has been heated by sitting in the sun for an extended period, the tach/gas gauge/temp gauge simply do not move - even after the car has been driven a significant distance. I've seen numerous prices for cluster repair, seemingly dependent on exactly what the problem is, ranging from 80 - 400 bucks. Does anyone have experience with this specific issue, and/or any idea where in that repair range this problem would fall?
Possibly related is a problem with the speedo needle - when cold, it is also dead, but DOES (usually) come back to life after being driven for a while. Would you think this is related to the other cluster issue I'm seeing, or would this seem to be an issue with the tranny speed sensor which I have seen mentioned as being problematic?
My next question concerns cost of repairs to the car. My brother is an ASE certified mechanic, and I'm a pretty good parts changer (although not a diagnostician). I figure that, between the two of us, repair manuals, and sites like this, we can fix 95+ % of problems that come up in the future. Let's face it, I'm only spending < $3k to buy it - I'm not going to take it in for dealer service for things that I don't have to. The question is, how many of the parts on this car are dealer specific? If I have a Chevy or Ford, I can go into any parts store in the country and damn near rebuild the whole car out of in-stock parts. Any DIYers here that can give me an idea of how often they'd send me off to the dealer for parts for this car?
Thanks
John Thomas
try hitting the dash above the guages while you're moving, not too hard though, that is a common problem, it's expensive to fix but a good tap does the trick, i have to do that in my car all the time.
parts are a real pain to find for our cars, and many tools are lexus specific. but the cars are really reliable if properly maintained. so it's really your call whether or not to buy it, i havent seen the car in person so idk. good luck though
Hey man sounds like it might be a good buy make it 2500 even.
As for the instrument problems call
Mikado Technology Company
8840 Forest St.
Gilroy, CA 95020
1.408.848.5000
They will fix you up for a good price.
Thanks for the replies.
Called Mikado - geve me a price range of 245 - 490, depending on exactly what needs done when he gets the unit. At $490, I'd essentially have a fully rebuilt cluster.
I saw this on ebay: cluster repair service for $160. The seller's id is mandigital, in Minnesota.
I wrote him and described the exact issues I'm having. He said all would be included in that price, except the one fading needle I have - replacing that would add $245. (ouch)
Has anyone used this person for these repairs?
Oh . . . and I guess I'm a member of the "family" here. When the Gen Mgr. for the Jag dealer, who happens to be a personal friend, tells you you should buy "that car" instead of getting one of their trade ins (at cost +$100.00), you know it's a good deal. :P
have jim walker do it....hes the best at it and has the most experience and is probably cheaper and will send u instructions on how to remove it
I'll probably go with Jim Walker, although he actually did NOT end up being the least expensive.
Everyone else I've emailed/called has given me a kinda generic answer.
Mr. Walker, on the other hand, gave a clear explanation of exactly what needed to be done, and which of my problems each repair item would correct. As he said in his email , though - "you have just about every problem that can go wrong" - which means that the total would be $625, plus 25 more if I want it overnighted back. :blink: :cries:
Ohwell. I knew going in that there would be some stuff that just can't be fixed cheaply on these cars. Guess I'll just have to suck it up and take it like a man. At least, since it'll be a fully reconditioned cluster, I shouldn't have any more problems with it.
