BlackLex Posted December 10, 2003 Share Posted December 10, 2003 <_< I see replacing brakepads can have a screeching result! Is this a result of forgotten parts during reinstall? Or do the ceramic take longer to seat than the softer bendix organic. I can get organic $50 cheaper than ceramic Need new brake pads SOON! Quote Link to comment Share on other sites More sharing options...
gaknut Posted December 10, 2003 Share Posted December 10, 2003 It is best for you to determine how the car is driven before choosing brake pads. Lots of high speed stops generate heat which demands ceramic pads. The ceramic will last longer, be less prone to fade on high speed stops, and have noticeably less brake dust but they also tend to be noisier and also will cause the rotors to wear out much faster. If you drive relatively easy organic pads will work satisfactorily for you, you'll simply have to replace them a little more often and they are much cheaper to replace. Several options are available for this reason. The most expensive in this case may not necessarily be the right choice. Quote Link to comment Share on other sites More sharing options...
RCRFAN3 Posted December 10, 2003 Share Posted December 10, 2003 I'm a break specialist, do not use the raybestos ceramic pads. They will warp the rotors in less than five thousand miles. Try using the Acebono (question spelling) the formula of the pad is a much better makeup than the Raybestos on the rotors. No warping. Quote Link to comment Share on other sites More sharing options...
SRK Posted December 10, 2003 Share Posted December 10, 2003 Don't fool around with the brakes on these cars. Buy the Lexus (Toyota) original part. That way you get the best pedal feel, quiet, relatively dust free, and they last very well. Japanese street car brake technology is among the best there is. I have used Raybestos carbon metallic brake pads in my other car. They are very impressive. The Raybestos name is "Brute Stop". The red painted base Raybestos pads are less than impressive. I cannot understand how a pad could warp a rotor, regardless of brand. They can wear the rotor at different rates depending on the material they are made from, but warping is caused by other variables in my experience. Quote Link to comment Share on other sites More sharing options...
jdmparts_guru Posted December 10, 2003 Share Posted December 10, 2003 I have used Axxis deluxe plus rear pads on my GS and they are very quiet and also very low dust. However, in my opinion if you are not looking for high performance pads, I would stick to the Toyota OEM pads. Don't be scared away by the expensive Lexus dealership pricing. Probably shopping around will give you better pricing. Quote Link to comment Share on other sites More sharing options...
Lextech2k3 Posted December 10, 2003 Share Posted December 10, 2003 I don't know how you drive your car but one of the sales people at the dealership i work at has been running some EBC Green Stuff brake pads on his '01 ES300. Now he has had excellent results for the three months he has had them..you may want to look into thier Red Stuff product it's for moderately agressive driving, and would do well on a coupe. Quote Link to comment Share on other sites More sharing options...
Lextech2k3 Posted December 10, 2003 Share Posted December 10, 2003 oh btw the factory uses a ceramic semi-metallic pad that does just fine till you try to stop from about a buck twenty on the highway. Quote Link to comment Share on other sites More sharing options...
LEXDOGG Posted December 10, 2003 Share Posted December 10, 2003 I run carebon metallic on my ls and I havent had no problems. I have about 9,000 miles on them. Quote Link to comment Share on other sites More sharing options...
Lextech2k3 Posted December 10, 2003 Share Posted December 10, 2003 what brand LEXDOGG? Quote Link to comment Share on other sites More sharing options...
jdmparts_guru Posted December 10, 2003 Share Posted December 10, 2003 The EBC RedStuff is not recommended if you want 'noise-less' pads. The RedStuff are for street racing purposes, and the rule of thumb is that the more hi-performance/racy the pads, the more dust and noise they generate. EBC pads are often very nice, but wear quickly and are not cheap. Quote Link to comment Share on other sites More sharing options...
mobilyte Posted December 10, 2003 Share Posted December 10, 2003 message deleted Quote Link to comment Share on other sites More sharing options...
