Abs Light
After I change transimission for es300 1995 the ABS light came on ,I took the car to the shop they give me the codes 32 and 34 from the scanner or computer and they did not explain in detail what these code means.They said they need more time to look at it and i don't have $70 every hour for them to check it again. If any one knows what i did wrong i will appreciate
my abs and trac cntrl light is on all the time, the trac light flashes, cant stand seeing blinking yellow lights, but I like the car without these features, except in snow lol.
Those lights being on at the same time do not indicated that those features are turned off, usually if they are both on at the same time it indicates a problem.
