JerryHonolulu Posted January 20, 2008 Share Posted January 20, 2008 I have a '91 LS400 with 116,000 miles on it. Both front, and one rear, air struts have been replaced in the last five years. Recently, when the car is parked and not driven for two days or so, the front of the car drops all the way down, both sides equally. When I start the engine, the air suspension pumps back up fairly quickly, and I have no problem with maintaining ride height while driving. Since the problem is common to both sides, and only the front, I suspect a check valve, or something similar, which is supposed to hold the air pressure to both front struts when the engine is off. Possibly the Ride Height Control Valve #1? Has anyone else had this problem, and what was done to correct it? I want to have as much information in hand as I possibly can before going in to the Lexus dealership for repair. Thanks for your help. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted January 21, 2008 Share Posted January 21, 2008 Need to spray the system from the shocks back with soapy water Quote Link to comment Share on other sites More sharing options...
eatingupblacktop Posted January 21, 2008 Share Posted January 21, 2008 When you turn the car off listen for a leak at the top of your struts under the hood. Also check the air lines to/from the components (compressor, height controller etc) for leaks. Look for bubbles as SK suggests. Quote Link to comment Share on other sites More sharing options...
