killerFatty Posted December 11, 2009 Posted December 11, 2009 I'm not sure what you mean by "external" and "internal" leaks, but you can bypass the speed-sensitive steering by removing the flow control valve, installing a bolt where it used to be, removing the small hoses connected to the intake manifold, and installing vacuum caps where they were connected. If I just put a vaccum cap on the line going to the front of the intake manifold will that stop the smoke then? I'm not sure exactly what you mean by putting a bolt where the control valve is. A pic would be great if somenone has one of how to remove the valve and bolt it closed. Sorry if I seem stupid I'm just trying to make sense of this.
AzHotLS Posted December 11, 2009 Posted December 11, 2009 killer, this thread has some pics showing the bolt used. http://us.lexusownersclub.com/forums/index...showtopic=60012
killerFatty Posted December 11, 2009 Posted December 11, 2009 Thx AzHotLS. That helped reassure me quite a bit. I put a screw in the hole on the front of the intake manifold and it seemed to stop the smoke. I'll be able to tell for sure tomorrow morning.
90LS400Lexus Posted December 12, 2009 Posted December 12, 2009 Not sure if its right or not, but this is how I was told to run the vac lines after blocking the idle-up valve. I was also told you can simply "cap" both of these off with those little caps. My smoke on start up went away immedietly once we did this. The idle-up valve was never causing my car to drip the fluid on the ground... it was only causing the embarrasing smoking on start-up. The external leak ended up being the return line on the back of the reservoir. Leaked for two years and I never knew thats what was leaking. It was a $2 hose and about 10 minutes to replace.
VigorousBrando Posted September 8, 2011 Posted September 8, 2011 Hi, The most probably cause is the o ring seal on the reservoir this is available from Lexus at around $6.00 Part # 90080-30040 You need to remove the low pressure return pipe and 3 bolts holding it to the pump. ( you don't have to remove the pump itself) Remove as much fluid as you can 1st using a rubber bulb type chicken baster then put plenty of rags under the pump to catch any remaining fluid. Here are some pictures showing the bolt locations and the o ring. http://i39.photobucket.com/albums/e191/ste...exuspspump1.jpg http://i39.photobucket.com/albums/e191/ste...exuspspump2.jpg Reassemble then top up the ps fluid and bleed the system. Good luck Just wanted to thank you for this suggestion. I think it's going to solve the issues I'm beginning to have with my pump which was just replaced a couple years ago. The car leaks a small amount of fluid after it is turned off and left alone, and I suspect it is coming directly from the pump. The system does not "whine" while in use or act up, but i know P/S fluid bis leaking somewhere because the reservoir needs refilled routinely. Hopefully an O-Ring is all I need, but are there any other things I should be looking for?
otherworldliness Posted September 9, 2011 Posted September 9, 2011 Hi, The most probably cause is the o ring seal on the reservoir this is available from Lexus at around $6.00 Part # 90080-30040 You need to remove the low pressure return pipe and 3 bolts holding it to the pump. ( you don't have to remove the pump itself) Remove as much fluid as you can 1st using a rubber bulb type chicken baster then put plenty of rags under the pump to catch any remaining fluid. Here are some pictures showing the bolt locations and the o ring. http://i39.photobucket.com/albums/e191/ste...exuspspump1.jpg http://i39.photobucket.com/albums/e191/ste...exuspspump2.jpg Reassemble then top up the ps fluid and bleed the system. Good luck Thank you as well. The photos are very useful.
