OK Ive looked at alot of intakes and it seams that the only one that actually connects to the stock will say ram air spot on top of the radiator is the srt kit. Is there another kit that does the same? I just think that even though the k and n one is next to it that it would still be better to be getting the air forced in through a tube than comeing in and getting sucked in all around it. Any input??
thanks
I was looking around and found dyno results for the joez intake and blitz filter at 7 hp gain. I also found the rod millen sport intake that sas that it produces 17 more hp. But they dont have a dyno sheet proving it. Has anyone used or have the rod millen intake or a link to dyno results?
i use the joez and blitz filter and i like it a lot, it's more aggressive above 3rmps. i think that the pipe itself gives a 7hp boost, not including the filter, although i'm not positive. and it's much cheaper than the srt!
  • 2 months later...
You might have a pop-up blocker or something, I just clicked on it and it worked fine.
