Limited Slip
Piranha
there are 2 main types of lsd's
the viscose which is clutch bands inside a goo that when one wheel is slipping makes one set of clutches spin and heat the goo causing contact and turning the opther wheel in the same rotation
the other is a mechanical one
which is the use of gears it causes a basic gear set i think planetary to spin locking both wheels together
