Brake Pad Replacements
The brake pads on my 2001 GS300 need to be changed.
What seem to perform the best: quietest and longest?
Ceramic Pads
Semi-metallic pads (which I expect would be noisy!)
Original Equipment Pads?
What is the best wisdom out there?
  • 3 weeks later...
  • 1 month later...
the oe pads are ceramic. stick with those
They are not ceramic...they are semi mettalic
Just changed my 2000 GS300 pads myself and I believe they were Ceramic. They were a japanese make, not oem, but was one of the easiest brake jobs I have done. Less than $100 and a hour or so labor. Changed at 75K and the rear brakes were less than 50% worn. New aftermarket pads feel great.
PS Metallic, not mettalic. Spell check is a brilliiant tool.
Would you recommend going to only Lexus to get new brake pads?? I would like to try and find someone else in Chicago, besides Lexus.. Is that a bad idea??
You'd save a lot of money buying the pads from irontoad.com or l-tunedparts.com or lexus-parts.com they cost a lot less to buy the pads there then have any decent mechanic put them in. The job itself is not at all complicated or difficult.
