there are 4 plugs under the pioneer (non CD) head unit when you remove the center console bezel, plug on the left as you are looking at it is orange, then to the right of that is a green plug, then a 15 pin white plug to the right of that, and a grey plug on the right most side
the white 15 pin plug carries stereo (the grey is climate control, not sure about green or orange)
looking for pin outs on the white plug to try to pick out the audio wires to the amp in the trunk
if I look at the face of the plug I have a 3 rows of 5 pins across.
numbered left to right starting on the top row I have:
1 green/red stripe
2 brown
3 blue/yellow stripe
4-5 blank
6 white/red stripe
7 purple
8 pink
9-10 blank
11 white
12-13 - connector clip
14-15 blank
assuming blue/yellow is power, and that brown is ground. heading out to read those out with the meter soon.
appreciate any help I can get here, thanks in advance
is it bad form to post this same info/question in the audio section?
  • 3 weeks later...
1 green/red stripe
2 brown
4-5 blank
6 white/red stripe
7 purple
8 pink
9-10 blank
11 white
14-15 blank
1 green/red stripe
2 brown
4-5 blank
6 white/red stripe
7 purple
8 pink
9-10 blank
11 white
14-15 blank
Nakamichi or premium ?
