This might be a silly question. :huh:
Is it possible change head light socket from 9004 type to H4 or H7?
Because now the H4, H7 light bulb are popular, and easy to get.
Thanks! :P
Yes it is possible.
not kidding, my 1990 LS400 has H4 on driver side and HB1 (9004) on the other side. Both 2 head lamp assembly are OEM
Thanks qha_vn
It's good to hear this, now I have chance to select a better light bulb. :)
Let us know how this goes--hopefully it's just a matter of trimming the tabs.
Yes it is possible.
The driver side headlight may be from an 93-94 LS400 if it uses an H4 bulb.
so H4 is an improvement over HB1????
i myself find H4 the better choice in terms of popularity, would consider replacing HB1 side (around 250 bucks)
250 buck? that should be the whole lamp assmbly right?
I just want to modify the socket to fit in H4 bulb only, cost should not more than 10~20 bulk;
Is it possible? :blushing:
