The RPMs seem to hold when moderately taking off from a dead stop, with about 25% pedal push. Basically the RPMs hold at 2000 then goes. Its a 05 with 9k miles. It does not really do it at WOT. Thanks
If u r looking for better launches without the RPM's holding @ 2000rpm, turn the traction control off...If you have LSD u will fly off the line!!!!!
You may have a sticky throttle causing the spring on the back of the pedal to be engaged taking up the slack to reduce power surges.
Clean your throttle body first.
Go get a can of electronics cleaner at Auto Zone or whatever store you prefer and clean the MAF sensor. There a numerous posts on how to do this, should take you about 10 minutes.
It cured my hesitation.
Turn off traction control for the best launch. It is VERY invasive :)
