godpossessed Posted March 19, 2007 Share Posted March 19, 2007 The driver's side valve cover gasket seems to be leaking onto my exhaust manifold. How hard is the fix to do? thanks Mark Quote Link to comment Share on other sites More sharing options...
blake918 Posted March 19, 2007 Share Posted March 19, 2007 Mark, it's not diffiult at all. You are basically just removing the timing belt cover, setting a couple rubber hoses to the side, moving the spark plug wires aside, and you have very easy access to the bolts that hold the valve cover on. Quote Link to comment Share on other sites More sharing options...
djspawn00 Posted March 19, 2007 Share Posted March 19, 2007 Its not the hardest thing to do if you're handy just remember where each part goes back and don't overtighten anything, use the correct amount of torque for your application. Quote Link to comment Share on other sites More sharing options...
godpossessed Posted March 20, 2007 Author Share Posted March 20, 2007 thanks guys, I think I can do that Mark Quote Link to comment Share on other sites More sharing options...
sheab Posted March 20, 2007 Share Posted March 20, 2007 thanks guys, I think I can do that Mark dont forget to replace both side or els soon or leater it will start to leak again ! Quote Link to comment Share on other sites More sharing options...
qha_vn Posted March 20, 2007 Share Posted March 20, 2007 when doing the sealing for your valve cover, check the PCV valve as well to make sure it is not stuck close resulting in unnecessary high pressure inside the engine that may lead to oil leaking Quote Link to comment Share on other sites More sharing options...
9779 Posted March 20, 2007 Share Posted March 20, 2007 Glad to hear how easy this is. I am about to have to change my gaskets as well. Are there any good manuals out there that I can get to help me with this and other repairs? I just bought a 97 LS400 and would like to do as much of the work as I can. Quote Link to comment Share on other sites More sharing options...
