What's This Part Called?
cmshoot
It's on my 2000 LS400. It's a large plastic piece of molded black plastic that is underneath the engine. It is the width of the car and goes back to the transmission, held on with several bolts. You have to remove it to change the oil. It's the bottom-most piece under the engine.
Mine has a few cracks in it and I'm looking on line for a new, but it would help if I knew it's correct name.
Thanks y'all.
If the cracks are located around the bolt mounting points you can use a large washer slipped over the bolt. I did this on mine and my 1990 still has the original undercover.
