Lex01_430 Posted March 5, 2007 Posted March 5, 2007 is it normal to have a melted lens? apparently mine melted a hole in the lens
dcfish Posted March 5, 2007 Posted March 5, 2007 is it normal to have a melted lens? apparently mine melted a hole in the lens Probably el cheapo aftermarket bulbs. Replace with oem and search for a new/used lens. Be sure to check the socket and wiring when you repair.
Lex01_430 Posted March 5, 2007 Author Posted March 5, 2007 i think these are the OEM...how can you tell?
djspawn00 Posted March 6, 2007 Posted March 6, 2007 Even an aftermarket bulb shouldn't burn the lens.. unless it was physically touching the lens. Were the bulbs unusually bright? If it wasn't touching the lens then the wiring or fuse should've burned out first.
