is it normal to have a melted lens? apparently mine melted a hole in the lens
Probably el cheapo aftermarket bulbs. Replace with oem and search for a new/used lens. Be sure to check the socket and wiring when you repair.
Even an aftermarket bulb shouldn't burn the lens.. unless it was physically touching the lens. Were the bulbs unusually bright? If it wasn't touching the lens then the wiring or fuse should've burned out first.
