imtheking Posted December 12, 2006 Posted December 12, 2006 1998 Gs300 Here is the deal..I have an aftermarket radio in my car which was installed by circuit city. They had to do a little rewiring since I had a factory amp in the car already...everything was perfect. I also added some subs and an amp. this was 2 years ago.... So last friday someone broke into my car and tried to steal the radio. they disconected all the wires and for some reason couldnt disconnect the last wire...looks like a harness... So today I take it to a shop to reinstall it and he looked at all the wires and said he has to test them to see where they go etc. Now, I dont know exactly what this guy did, but the sound quality of my speakers are absolutely horrible now! There is static/distortion on all 4 speakers, and the factory tweeters are not putting out "highs" like before. Question is, even though the radio/subs work, can a wrong rewire job by the guy cause this? Could it be my ground wire causing this?
djspawn00 Posted December 13, 2006 Posted December 13, 2006 the wiring if probably reversed... ie.. negative wire mistaken for positive, or a bad ground wire...
Abear Posted December 13, 2006 Posted December 13, 2006 Yeah. Should take it back to Circuit City, or mess with it yourself if you know what your doing.
imtheking Posted December 16, 2006 Author Posted December 16, 2006 Yeah. Should take it back to Circuit City, or mess with it yourself if you know what your doing. took radio out and just plugged everything back in again...also messed with ground wire and all is good now :)
93LSOwner Posted December 16, 2006 Posted December 16, 2006 installed by circuit city. took radio out and just plugged everything back in again Should have installed it yourself the first time. ;) Circuit city..................... :chairshot:
tnythtgr Posted January 18, 2007 Posted January 18, 2007 Definitely one of two things: Most likely the problem is that your positive and negative speaker wires are either touching, or reversed. Try switching them around to see if you get a better sound. If not, try using electrical tape around where they are connecting to the speaker and make sure there are no frayed wires splitting off and touching anywhere on the speaker or surrounding areas. The second, less likely but still possible problem is your ground wire is bad. Try finding a spot on your car that is BARE METAL. This seems easy but can be difficult. If you can't find a good ground spot, try using a multimeter to test and find a good ground spot. These are simple solutions that can easily be done at home. I would say go to Circuit City but those jack asses will probably just screw it up some more.
