njmurvin Posted November 21, 2006 Share Posted November 21, 2006 My daughter has a 97 ES300 that we purchased at 70k. It now has about 150k and I'm not sure the trans has ever been serviced since 70k (or before, for that matter). My indy mechanic says the fluid looks OK but has recommended sending out to the local oil change guy to do a tranny flush. I have read numerous nightmare stories - particularly about older transmissions that haven't been meticulously maintained being flushed (flushing causing the movement of particles into VBs etc.). Anyway, is it better to just drain/fill a couple of times in our case or should I let them flush it? Is there a replaceable filter in the trans? How much would Lexus charge me to do a trans service and would they flush it? Quote Link to comment Share on other sites More sharing options...
dcfish Posted November 21, 2006 Share Posted November 21, 2006 My daughter has a 97 ES300 that we purchased at 70k. It now has about 150k and I'm not sure the trans has ever been serviced since 70k (or before, for that matter). My indy mechanic says the fluid looks OK but has recommended sending out to the local oil change guy to do a tranny flush. I have read numerous nightmare stories - particularly about older transmissions that haven't been meticulously maintained being flushed (flushing causing the movement of particles into VBs etc.). Anyway, is it better to just drain/fill a couple of times in our case or should I let them flush it? Is there a replaceable filter in the trans? How much would Lexus charge me to do a trans service and would they flush it? Drain and fill, Drain and fill, Drain and fill... You get the idea... Quote Link to comment Share on other sites More sharing options...
backwoods lex Posted November 21, 2006 Share Posted November 21, 2006 A while ago, I actually figured out how many drain and fills it would take to get from 100% contaminated atf to 100% clean fluid. I think it was something like: 1st drain 8 quarts (old atf - 4 quarts drained)0% + 4quarts 100% =33% clean 2nd drain 8 quarts (old atf now at 33%) + 4 quarts 100% =55% clean 3rd drain 8 quarts (old atf now at 55%) + 4 quarts 100% =70% clean 4th drain 8 quarts (old atf now at 70%) + 4 quarts 100% =80% clean and on and on... Is this right? Quote Link to comment Share on other sites More sharing options...
Toysrme Posted November 22, 2006 Share Posted November 22, 2006 Not really. Dry fill - 6.75 liters (7.10 US qts, 5.94 Imp.qts) Drain and refill - 2.5 liters (2.6 US qts, 2.2 Imp.qts) Differential oil - 0.85 liters (0.89 US qts, 0.75 Imp.qts) All Dexron-III It says 2.6qts. But I think that's a bit wrong. I think they're measuring just the pan capacity & not including what will drain back out of the valve body & dump to some extint. 'cause I get more around 3 quarts out most of the time than 2 1/2. So it's a 7 qt system. It'd take 3 drain & fills & shift to all positions & drive around abit & park & shift to all positions again to statistically change the majority of the fluid. Which is close enough. To me, it just takes little time to flush one using the cooler lines instead of doing that 2-3-4+ times. So I do it that way. Quote Link to comment Share on other sites More sharing options...
mburnickas Posted November 22, 2006 Share Posted November 22, 2006 I do a drain (tranny and diff) and it takes about 3.75 qts. Quote Link to comment Share on other sites More sharing options...
anthonyiez Posted November 22, 2006 Share Posted November 22, 2006 i've never had a problem flushing a high mileage trans in these vehicles. flushing (done properly) is hands above draining and refilling. Quote Link to comment Share on other sites More sharing options...
coolwater Posted November 22, 2006 Share Posted November 22, 2006 I am sorry but I'm not clear on 'drain & refill' action. Is it... drain --> refill --> drive for some miles --> drain again --> refill again --> drive for some miles again --> drain again --> refill (???) or, is it just... drain --> refill --> drain without driving --> refill --> drain without driving --> refill (???) Also, is there a filter for the transmission fluid like the oil filter?? If yes, does it have to be changed as well?? Quote Link to comment Share on other sites More sharing options...
dcfish Posted November 22, 2006 Share Posted November 22, 2006 I am sorry but I'm not clear on 'drain & refill' action. Is it... drain --> refill --> drive for some miles --> drain again --> refill again --> drive for some miles again --> drain again --> refill (???) or, is it just... drain --> refill --> drain without driving --> refill --> drain without driving --> refill (???) Also, is there a filter for the transmission fluid like the oil filter?? If yes, does it have to be changed as well?? Drain> Fill>Drive, Repeat. Quote Link to comment Share on other sites More sharing options...
anthonyiez Posted November 22, 2006 Share Posted November 22, 2006 the thing is no matter how many times you drain/refill it can never be the same as a complete flush Quote Link to comment Share on other sites More sharing options...
mburnickas Posted November 22, 2006 Share Posted November 22, 2006 I have never flushed a tranny since I have been driving. I always drain and refill with proper synthetic fluid. Then I drain between 25 to 35K and do it again. Samething over and over. Quote Link to comment Share on other sites More sharing options...
dcfish Posted November 22, 2006 Share Posted November 22, 2006 I have never flushed a tranny since I have been driving. I always drain and refill with proper synthetic fluid. Then I drain between 25 to 35K and do it again. Samething over and over. Agreed Quote Link to comment Share on other sites More sharing options...
camlex Posted November 23, 2006 Share Posted November 23, 2006 I did my first trans. flush at 131,000. but i requested toyota not to use any chemicals. Presently I have 220,500 . No problem. After last flush@131,000 i started drain and refill every 15,000 and next 15000 take it to mechanic to drop pan change filter and refill. Happy Thanksgiving to all. Hope that helps. Quote Link to comment Share on other sites More sharing options...
dcfish Posted November 23, 2006 Share Posted November 23, 2006 I did my first trans. flush at 131,000. but i requested toyota not to use any chemicals. Presently I have 220,500 . No problem. After last flush@131,000 i started drain and refill every 15,000 and next 15000 take it to mechanic to drop pan change filter and refill. Happy Thanksgiving to all. Hope that helps. There is no filter to change, Just a couple of magnets to clean off and a screen. :whistles: Quote Link to comment Share on other sites More sharing options...
camlex Posted November 23, 2006 Share Posted November 23, 2006 that is called filter. I like to replace because it's hard to clean. Quote Link to comment Share on other sites More sharing options...
coolwater Posted November 23, 2006 Share Posted November 23, 2006 What's AT Filter then? I see there are Type A and Type B AT Filters. Quote Link to comment Share on other sites More sharing options...
Toysrme Posted November 24, 2006 Share Posted November 24, 2006 It's the fluid pick-up. Its reffered to a filter because it has a pick-up screen. Quote Link to comment Share on other sites More sharing options...
anthonyiez Posted November 24, 2006 Share Posted November 24, 2006 I have never flushed a tranny since I have been driving. I always drain and refill with proper synthetic fluid. Then I drain between 25 to 35K and do it again. Samething over and over. i know a lot of people that never perform a flush, that doesn't make it correct though. Quote Link to comment Share on other sites More sharing options...
Toysrme Posted November 24, 2006 Share Posted November 24, 2006 Just aslong as you get rid of the old crap I don't care. I've done asmany transmission flushes using the cooler lines as I have drain & fills during oil changes. Personally. On mine I flush them & go 2-3 years doing pan drains during oil changes before I flush them again. Quote Link to comment Share on other sites More sharing options...
