norbertk Posted July 6, 2006 Share Posted July 6, 2006 I found a few topics, so I went in and changed all the bulbs, but the indicator keeps coming on. I changed the brake light (inside), license plate lights, and all bulbs in the tail. Do I need to unplug my battery for a little bit, or any other suggestions? Quote Link to comment Share on other sites More sharing options...
SKperformance Posted July 6, 2006 Share Posted July 6, 2006 Tap the bulbs and look for any changes. Quote Link to comment Share on other sites More sharing options...
norbertk Posted July 6, 2006 Author Share Posted July 6, 2006 Will it update the indicator while I tap them? Because it only goes on once I press down on my brake pedal. Quote Link to comment Share on other sites More sharing options...
mburnickas Posted July 6, 2006 Share Posted July 6, 2006 Will it update the indicator while I tap them? Because it only goes on once I press down on my brake pedal. This is WEIRD!!!My co-worker has a 99 that does the samething. Only comes on when he hits the brakes and all bulbs are working.... Quote Link to comment Share on other sites More sharing options...
amf1932 Posted July 6, 2006 Share Posted July 6, 2006 Will it update the indicator while I tap them? Because it only goes on once I press down on my brake pedal. Once the indicator light goes on you have to turn off the ignition and start all over again. A good reason for the triggering of the indicator light could also be because of oxidation in the bulb sockets. They sell contact cleaner in electronic stores which will remove this oxidation. Quote Link to comment Share on other sites More sharing options...
norbertk Posted July 6, 2006 Author Share Posted July 6, 2006 I mean originally, it went on because my license plate lights were out, so I replaced those, and the indicator still goes on. I'll try playing with it later tomorrow. Quote Link to comment Share on other sites More sharing options...
lexusk8 Posted July 6, 2006 Share Posted July 6, 2006 When I had my '96 ES, a license plate light burnt out, but the indicator light never turned on. From my experience, the indicator light will go on whenever a tailight bulb or brake bulb is burnt out, or not making a clean connection with the socket. It has nothing to do with the license plate lights. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted July 6, 2006 Share Posted July 6, 2006 Lexusk8 is right , the indicator is only for brake lights it has nothign to do with the other turn ,reverse , or parking lights. 92-94 has 3 per side and 2 upper 3rd brake lights 95-96 only has 2 per side Quote Link to comment Share on other sites More sharing options...
norbertk Posted July 7, 2006 Author Share Posted July 7, 2006 I went in again and checked all the sockets with my ohm meter. All the sockets were reading about 55 ohms, except for one which read about 45. I cleaned it thorougly and still same read. The indicator is still on, and it's really starting to aggrivate me. Quote Link to comment Share on other sites More sharing options...
rosecityrain Posted July 7, 2006 Share Posted July 7, 2006 I found a few topics, so I went in and changed all the bulbs, but the indicator keeps coming on. I changed the brake light (inside), license plate lights, and all bulbs in the tail. Do I need to unplug my battery for a little bit, or any other suggestions? Mine was due to a wiring harness that had corroded. It still goes on sometimes and I just jiggle the harness near where the CD changer goes and it goes off...until next time. Seems to happen when it comes in contact with something in the trunk. rosie Quote Link to comment Share on other sites More sharing options...
lexuses drvr Posted July 8, 2006 Share Posted July 8, 2006 I found a few topics, so I went in and changed all the bulbs, but the indicator keeps coming on. I changed the brake light (inside), license plate lights, and all bulbs in the tail. Do I need to unplug my battery for a little bit, or any other suggestions? Mine was due to a wiring harness that had corroded. It still goes on sometimes and I just jiggle the harness near where the CD changer goes and it goes off...until next time. Seems to happen when it comes in contact with something in the trunk. rosie This sounds alot like you are having a brake lamp switch problem located on the brake pedal . Reason why I say is because you state it goes on either after or before braking . Either way its when you hit the pedal. May want to inspect that also . Quote Link to comment Share on other sites More sharing options...
mehullica Posted July 8, 2006 Share Posted July 8, 2006 poor quality, cheap bulbs will also cause the indicator to stay on as the bulbs draw the incorrect amperage Quote Link to comment Share on other sites More sharing options...
SKperformance Posted July 8, 2006 Share Posted July 8, 2006 It is not the brake pedal switch , The design of the indicator is so it can tell when there is a different current draw from lite brake lights . Otherwise how could it tell when one is burnt? Quote Link to comment Share on other sites More sharing options...
