Ac Stalls Engine
howudodat
92 LS400,
if I start the car with AC in auto, the engine starts and immediately stalls.
if I start the car with NO AC, the engine runs fine
if I start the AC after the car is running, the engine stalls
if I hold the RPM's at ~1500 the engine wont stall, but noticeablly loads down
no cold air blows out.
I'm thinking the compressor has gone bad, or frozen and is loading down the system. I wanted to see if anyone else has seen this problem before I invest in a new compressor.
Peter
I would also advise to NOT turn it on anymore. If it's got so much load resistance on it now to stall the entire engine, then I can only imagine the amount of strain it's putting on all the other components...aka....drive belt and possibly the timing belt.
