vandalyze Posted April 27, 2006 Posted April 27, 2006 I have a IS350 with the premium package with the 18" rims. When I make tight turns or make a u-turn, I hear and kind of feel a grinding noise in the front. It sounds like the road or something grainy. Is this normal? Has anybody experienced this? Thank you very much.
webdev Posted April 27, 2006 Posted April 27, 2006 I hear this as well.. kinda sounds like the brakes pads are touching the rotors. Anyone else hear this noise?
omad Posted May 1, 2006 Posted May 1, 2006 I have a IS350 with the premium package with the 18" rims. When I make tight turns or make a u-turn, I hear and kind of feel a grinding noise in the front. It sounds like the road or something grainy. Is this normal? Has anybody experienced this? Thank you very much. I heard it too, I took it to lexus, actually 2 lexus dealerships and they told me the tires are wide and they rub aggainst the car. probably B.S., b/c i too only hear it on the right -omad
murph550 Posted May 2, 2006 Posted May 2, 2006 Yea, I have a 250 awd and have noticed the same noise, but only when cutting the wheel all of the way.
CariSoul Posted May 2, 2006 Posted May 2, 2006 I have the 250 and it happens when turn the wheel all the way. Guess Lexus just let this pass!
TOBY Posted May 5, 2006 Posted May 5, 2006 If you ever notice that the turning radius on this car is very small. What you may be hearing is the tire rubbing against the road surface. The profile of the tire does not help either. There is very minimal sidewal/air to absorb noise. I too have the 18in wheel pkg. I'll keep an ear out also.
vandalyze Posted May 5, 2006 Author Posted May 5, 2006 If you ever notice that the turning radius on this car is very small. What you may be hearing is the tire rubbing against the road surface. The profile of the tire does not help either. There is very minimal sidewal/air to absorb noise. I too have the 18in wheel pkg. I'll keep an ear out also. Yeah. That's what I think too, but I wasn't too sure if it happens to my car only or other cars too. I was going to go out to the dealer to test drive another car to see if it made the same noise. :) Thanks.
Scott M Posted May 5, 2006 Posted May 5, 2006 You folks with the IS250 and 18" Wheels.... Is it safe to assume you all have RWD drive models? According to Lexus, the 18" Wheels are only available on RWD models. I assumed that this was due to clearance issues with the AWD model. Any of you guys running 18s on an AWD model?
bartkat Posted May 5, 2006 Posted May 5, 2006 You folks with the IS250 and 18" Wheels.... Is it safe to assume you all have RWD drive models? According to Lexus, the 18" Wheels are only available on RWD models. I assumed that this was due to clearance issues with the AWD model. Any of you guys running 18s on an AWD model? The guy that started this thread says he has a 350.
lex250awd Posted October 5, 2006 Posted October 5, 2006 You folks with the IS250 and 18" Wheels.... Is it safe to assume you all have RWD drive models? According to Lexus, the 18" Wheels are only available on RWD models. I assumed that this was due to clearance issues with the AWD model. Any of you guys running 18s on an AWD model? Yes, I am running 18 inch on 2007 IS250AWD and doing great! See photo attached.
Grnrex Posted March 13, 2007 Posted March 13, 2007 We have a 07 IS250 RWD with 18 inch wheels and at right or left max turning radius we get a clunking or jerking sensation from the front end. I took it in for the 5k oil change and service and asked the Fresno Lexus dealer to have the techs look at this problem. They told me that when they had it up on the lift they checked everthing out and all was as everything was suppose to be. They said they took another IS250 from the lot and drove it around and it did the same thing so it is alright. I just can't believe and engineer would design a steering system to do this.
seohenning Posted March 13, 2007 Posted March 13, 2007 You folks with the IS250 and 18" Wheels.... Is it safe to assume you all have RWD drive models? According to Lexus, the 18" Wheels are only available on RWD models. I assumed that this was due to clearance issues with the AWD model. Any of you guys running 18s on an AWD model? Yes, I am running 18 inch on 2007 IS250AWD and doing great! See photo attached. I am interested in getting 18's for my AWD - Anyone have suggestions?? Although I like the chrome I would rather not get them because I use my car for work purposes as well. So a machine faced might be a good option. I'd also like to keep the price reasonable due to the extra $500 for the TPM sensors. Thanks!
Scott M Posted March 13, 2007 Posted March 13, 2007 You folks with the IS250 and 18" Wheels.... Is it safe to assume you all have RWD drive models? According to Lexus, the 18" Wheels are only available on RWD models. I assumed that this was due to clearance issues with the AWD model. Any of you guys running 18s on an AWD model? Yes, I am running 18 inch on 2007 IS250AWD and doing great! See photo attached. I am interested in getting 18's for my AWD - Anyone have suggestions?? Although I like the chrome I would rather not get them because I use my car for work purposes as well. So a machine faced might be a good option. I'd also like to keep the price reasonable due to the extra $500 for the TPM sensors. Thanks! I went to Tirerack.com and went through the tire/wheel package section and found that they do offer 18" wheels for the IS250 AWD. Plus, lex250awd has an AWD and he's running 18"s So yeah, they'll fit, but I have no idea why Lexus doesn't offer them.
forourspam Posted January 3, 2010 Posted January 3, 2010 Sorry about reviving this old thread, but I am having the same issue. Did anyone get it resolved through Lexus?
GliTCH Posted June 12, 2010 Posted June 12, 2010 Sorry about reviving this old thread, but I am having the same issue. Did anyone get it resolved through Lexus? No, but I have the same issue as well. I imagine it's only one of many design flaws that are causing me to go through sets of tires like disposable napkins.
Nikonwil Posted July 27, 2019 Posted July 27, 2019 Hello, i just purchased an 06 Lexus IS250 AWD w/136k miles on it, and today while making a u-turn at about 25-30 mph it made that grinding noice. Another instance where I experienced something similar was while driving a 2015 Nissan Frontier on 4x4, it would make some kind of grinding noise//slipping feeling while making turns.. as if the wheels were sliding on ice. Last time I experienced something like this was on a 04 Toyota Corolla S when moving forward from a stop, it would make a grinding noise too. On the corolla it tuned out to be bad engine mounts; after replacing them with OEM mounts, the grinding noice was gone. If you find out what the issue is, please update this thread. Thanks!
missriley Posted December 1, 2022 Posted December 1, 2022 On 5/5/2006 at 5:37 AM, Scott M said: You folks with the IS250 and 18" Wheels.... Is it safe to assume you all have RWD drive models? According to Lexus, the 18" Wheels are only available on RWD models. I assumed that this was due to clearance issues with the AWD model. Any of you guys running 18s on an AWD model? I have a 2010 is 250 f sport AWD and my car does it too in the front when I am turning to park or something. It makes like this grinding noise and feeling. I get that everyone says its because the tires are big or whatever but is it going to cause any damage or is there a recall policy or something for lexus to fix. #lost
