dole2000 Posted April 9, 2006 Share Posted April 9, 2006 I have a 91 LS. Sometimes when I brake lightly, my front end shakes a bit. Doesn't do it all the time. Only when I have been driving awhile. Mostly going down hill in Mtns. etc.. I replaced the front pads. Got a little better. I have bremble rotors on the front. I think the calipers are orginal. Thanks, Bob Quote Link to comment Share on other sites More sharing options...
falciott Posted April 9, 2006 Share Posted April 9, 2006 Hey Bob, your car starts shaking after driving downhill for a while? Sounds like it might be the rotors, excessive heat tends to warp them, eventhough I am surprised to see that it should happen on your Brembo rotors, those rotors are pretty good, infact I do alot of downhill driving myself with Brembos without any problems. Just my two cents! :-) Quote Link to comment Share on other sites More sharing options...
jzz30 Posted April 9, 2006 Share Posted April 9, 2006 you should resurface the rotors if you havent done so when you changed pads Quote Link to comment Share on other sites More sharing options...
SW03ES Posted April 9, 2006 Share Posted April 9, 2006 Definately warped rotors. Quote Link to comment Share on other sites More sharing options...
Threadcutter Posted April 9, 2006 Share Posted April 9, 2006 I have a 91 LS. Sometimes when I brake lightly, my front end shakes a bit. Doesn't do it all the time. Only when I have been driving awhile. Mostly going down hill in Mtns. etc.. I replaced the front pads. Got a little better. I have bremble rotors on the front. I think the calipers are orginal. Thanks, Bob Bob: I agree with everyone else & would like to add that you may have a sticking piston in one or both of your calipers. I recently did my brakes, including re-building the calipers. It is a very simple procedure. Get the caliper on the bench, remove the piston & rubber boot. using a hook tool, remove the O-ring & replace it with new. Re-assemble, re-install, add pads, bleed & you're done. Brake rebuild Quote Link to comment Share on other sites More sharing options...
dole2000 Posted April 17, 2006 Author Share Posted April 17, 2006 I would like to thank everyone for their help. It was the Calipers. At least after replacing them the problem appers gone. Hard to get rotars turned on the weekend. Quote Link to comment Share on other sites More sharing options...
dole2000 Posted October 27, 2006 Author Share Posted October 27, 2006 I replaced the rotors, pads and calipers. It was good for about a month and started to shake again. Do I need a new steering rack? I have 250K and it looks a little worn. Quote Link to comment Share on other sites More sharing options...
bicol-ini Posted October 27, 2006 Share Posted October 27, 2006 did you have your rotor resurfaced or turned already? do this first, also did you your car have a 4 wheel alignment?, is your tires balanced? check this first, before you do your steering rack unless there is leakage, Quote Link to comment Share on other sites More sharing options...
dole2000 Posted October 27, 2006 Author Share Posted October 27, 2006 I put on new rotors, but I didn't do the four wheel alignment. Quote Link to comment Share on other sites More sharing options...
