Chaudary Posted February 26, 2006 Share Posted February 26, 2006 Can anybody please tell me if CD changer comes as standard in 1999 ES300 or is it optional ?? and does the radio automatically locks if the battery is disconnected for a certain time and how to unlock it. TIA Quote Link to comment Share on other sites More sharing options...
backwoods lex Posted February 26, 2006 Share Posted February 26, 2006 I unhook my negative battery cable every 5-10k for up to an hour (in order to restore factory settings for the transmission) and have never had any problems. I read in the owners maunual that you may need a code if you disconnect the battery, but I've never needed one. Quote Link to comment Share on other sites More sharing options...
Lexucan Posted February 26, 2006 Share Posted February 26, 2006 Can anybody please tell me if CD changer comes as standard in 1999 ES300 or is it optional ?? and does the radio automatically locks if the battery is disconnected for a certain time and how to unlock it. TIA CD changer as standard equipment in 1999 ES ? - don't know. I have a 1993 ES300 which does require a code for the radio if the battery is disconnected - that is if the radio's "anti-theft deterrant" system is activated. It can be deactivated too so no code is needed after a power disconnect. Does the front face of your radio have a small flashing LED when the car is turned off? If it does, you'll prolly need a code. I'd check the owner's manual - it should tell you. Quote Link to comment Share on other sites More sharing options...
chadmg7 Posted February 28, 2006 Share Posted February 28, 2006 When I replaced my battery, the car was without power for about 30-60 minutes and the only thing I had to reset was the clock. No problems with the stereo or anything else. Quote Link to comment Share on other sites More sharing options...
dcfish Posted February 28, 2006 Share Posted February 28, 2006 When I replaced my battery, the car was without power for about 30-60 minutes and the only thing I had to reset was the clock. No problems with the stereo or anything else. I'm 99% sure that cd changers were standard in the 1999es. As far as a code goes you probably won't need one, But if you do I beleive it is the last 4 digits of your key code. Or is it the last 4 #'s in the vin# Either way you get 10 tries before you have to bring it in to get decoded. Quote Link to comment Share on other sites More sharing options...
snohman Posted January 22, 2007 Share Posted January 22, 2007 Is there a connection for the CD changer other than in the back of the radio for 97 es300? The radio face says its CD ready...I have a changer I want to throw in...where do they mount it? I think Ive seen it mounted in the truck would that mean they have a connection back there or is it behind the radio? More than likely, sn Quote Link to comment Share on other sites More sharing options...
Lacebug Sydney Posted January 22, 2007 Share Posted January 22, 2007 Is there a connection for the CD changer other than in the back of the radio for 97 es300? The radio face says its CD ready...I have a changer I want to throw in...where do they mount it? I think Ive seen it mounted in the truck would that mean they have a connection back there or is it behind the radio? More than likely, sn I finally found an original sales brochure for my 2000 Es300 and it says that the 6-stack (in the glovebox) is an option. Stephen Quote Link to comment Share on other sites More sharing options...
lmk Posted April 18, 2007 Share Posted April 18, 2007 Is there a connection for the CD changer other than in the back of the radio for 97 es300? The radio face says its CD ready...I have a changer I want to throw in...where do they mount it? I think Ive seen it mounted in the truck would that mean they have a connection back there or is it behind the radio? More than likely, sn I finally found an original sales brochure for my 2000 Es300 and it says that the 6-stack (in the glovebox) is an option. Stephen ================ I have 99 ES300 without CD player/changer. Can someone suggest me how to get one installed? Where can I find it as Lexus dealer told me the parts are discontinued? Can the CD player/changer fit in the glove box? Can it play MP3? Thanks a lot! lmk Quote Link to comment Share on other sites More sharing options...
lexus411 Posted April 18, 2007 Share Posted April 18, 2007 I think on the ES you have to swap out the whole glove box for the cd w/ another car. It was still an option back then. Quote Link to comment Share on other sites More sharing options...
dcfish Posted April 18, 2007 Share Posted April 18, 2007 Is there a connection for the CD changer other than in the back of the radio for 97 es300? The radio face says its CD ready...I have a changer I want to throw in...where do they mount it? I think Ive seen it mounted in the truck would that mean they have a connection back there or is it behind the radio? More than likely, sn I finally found an original sales brochure for my 2000 Es300 and it says that the 6-stack (in the glovebox) is an option. Stephen ================ I have 99 ES300 without CD player/changer. Can someone suggest me how to get one installed? Where can I find it as Lexus dealer told me the parts are discontinued? Can the CD player/changer fit in the glove box? Can it play MP3? Thanks a lot! lmk I'll see if I have one for you, Hold tight, I'll get back with you. Quote Link to comment Share on other sites More sharing options...
LUTHOR-CL Posted May 9, 2007 Share Posted May 9, 2007 Is there a connection for the CD changer other than in the back of the radio for 97 es300? The radio face says its CD ready...I have a changer I want to throw in...where do they mount it? I think Ive seen it mounted in the truck would that mean they have a connection back there or is it behind the radio? More than likely, sn I finally found an original sales brochure for my 2000 Es300 and it says that the 6-stack (in the glovebox) is an option. Stephen ================ I have 99 ES300 without CD player/changer. Can someone suggest me how to get one installed? Where can I find it as Lexus dealer told me the parts are discontinued? Can the CD player/changer fit in the glove box? Can it play MP3? Thanks a lot! lmk I'll see if I have one for you, Hold tight, I'll get back with you. SO DOES THAT MEAN WE CAN JUST BUT THE CD CHANGER SEP. AND INSTALL THEM ON THE GLOVE BOX? I REALLY DONT WNAT TO REPLACE THE WHOLE RADIO. COZ I ALSO HAVE A 97 ES300 AND IT HAS THE CD FUNCTION BUTTON BUT NO ACTUAL CD PLAYER. THANKS. Quote Link to comment Share on other sites More sharing options...
leert12 Posted June 29, 2007 Share Posted June 29, 2007 Is there a connection for the CD changer other than in the back of the radio for 97 es300? The radio face says its CD ready...I have a changer I want to throw in...where do they mount it? I think Ive seen it mounted in the truck would that mean they have a connection back there or is it behind the radio? More than likely, sn I finally found an original sales brochure for my 2000 Es300 and it says that the 6-stack (in the glovebox) is an option. Stephen ================ I have 99 ES300 without CD player/changer. Can someone suggest me how to get one installed? Where can I find it as Lexus dealer told me the parts are discontinued? Can the CD player/changer fit in the glove box? Can it play MP3? Thanks a lot! lmk I'll see if I have one for you, Hold tight, I'll get back with you. SO DOES THAT MEAN WE CAN JUST BUT THE CD CHANGER SEP. AND INSTALL THEM ON THE GLOVE BOX? I REALLY DONT WNAT TO REPLACE THE WHOLE RADIO. COZ I ALSO HAVE A 97 ES300 AND IT HAS THE CD FUNCTION BUTTON BUT NO ACTUAL CD PLAYER. THANKS. If that's the case, then it should work with a changer that should be able to mount in the glove compartment. I took out mine 2001 from the glove compartment. And yes the Face Head Unit does say CD option but it has a cassette slot, I'm assuming the 99 is the same. Thus, check for the connection in the glove box and it it is there, then you;re good to go. Next, you'd have to find the code on back of Head Unit, looks like this 86120-33320. Call the dealer and find out which CD Changer will work. Mine is matched up with the Changer that has the numbers 86270-33040 on back of Changer. Quote Link to comment Share on other sites More sharing options...
Leanne P Halfman Posted January 31 Share Posted January 31 leanneph911@aol.com My 1999 Lexus ES300 Cassette player will not accept another cassette after having to EXTRACT a STUCK cassette Any suggestions or recommendations? thank you Quote Link to comment Share on other sites More sharing options...
