I tried to search the forum before I asked this question...I could only find information about the earlier models.
I have a 96 ES300 and my Check Engine light came on. I have a OBDII code scanner, but I have not been able to locate the connector. I checked the engine compartment and the passanger compartment, with no luck.
Any help would be appreciated.
Thanks,
Scott
Thanks,
Scott
I don't think the 96 is OBDll it might be OBDl, Look into it further, I could be wrong.
Thanks for your help. That may be the case, but I thought that OBDII was mandatory on 96 and newer cars. I may have to call the dealer on Monday.
Scott
Scott
You are probably right, Easy enough to look up. :cheers:
94 ES 300 with a 1mz-fe was the worlds first OBD-2 compliant car.
So Yes your car is OBD-2.
Second the connector is located inside the fuse panel to the left of the steering wheel. Pop off the cover and it is in there.
Here u go... this will help what Sk was talking about.
http://www.troublecodes.net/Lexus/
N u can pull what the codes r here.
U can also download the FSM (Full Service Manual) for ur generation. They will also tell u how to check. Go to the diagnostic PDF n go to around Page 3 or so.
http://us.lexusownersclub.com/forums/index...showtopic=26449
It was generously donated by Toysrme.
Tom
Edited by kcpth
My mistake... i stand corrected... I'm sure santamre :ph34r: had a !Removed! finger with all those typing at the end of Xmas. Thanks for the gift. Proved very useful to many people. ;)
Thanks for everyones help... I was able to find the OBDII Connection and read and clear the code.
Thanks again,
Scott
