rexlex Posted August 29, 2005 Posted August 29, 2005 Where are they? How many here just do drain and fill? Is it really necessary to do flush?
SKperformance Posted August 29, 2005 Posted August 29, 2005 Why would you want to remove drain plugs when you can do a flush much better?
wwest Posted August 29, 2005 Posted August 29, 2005 There are no engine block drain plugs. You may be thinking of freeze plugs which are not normally removed.
rexlex Posted August 31, 2005 Author Posted August 31, 2005 HOW DO YOU DO YOUR COOLANT FLUSHES ON YOUR RX300?
SKperformance Posted August 31, 2005 Posted August 31, 2005 buy a prestone flush kit and do it yourself real easy.
wwest Posted August 31, 2005 Posted August 31, 2005 I NEVER do coolant flushes absent a repair that requires it or the coolant degrades beyond the anti-freeze level I require (Seattle area) or if the Ph goes out of whack. The only exception was that I changed out the factory coolant in my 1992 LS400 about two years ago, 11 years and 100,000 miles, simply because it was looking a little murky.
mehullica Posted September 1, 2005 Posted September 1, 2005 2 block drains. 1 near the oil filter. 1 near the timing belt tensioner. Both have a 17mm fitting with a 10mm drain petcock.
rexlex Posted September 1, 2005 Author Posted September 1, 2005 2 block drains. 1 near the oil filter. 1 near the timing belt tensioner. Both have a 17mm fitting with a 10mm drain petcock. ← Thanks Mehullica. You ar :) e the only one on all the 60 boards here that answered my question
