thewzdoc Posted July 9, 2003 Share Posted July 9, 2003 Where is the fuel filter and what is the best replacement to use? Truthfully I haven’t looked all that hard for its location. I was hoping that someone here had already done the legwork. Are there any pictures? Quote Link to comment Share on other sites More sharing options...
jzz30 Posted July 10, 2003 Share Posted July 10, 2003 theres one in the gas tank as there is in most all cars right before the pump, i dont know if there is one on the way to the engine bay, and there should be a canister looking thing that fuel lines run to before it is sprayed in the engine, change it with O.E.M. its probably the best out there. Quote Link to comment Share on other sites More sharing options...
mig25 Posted July 12, 2003 Share Posted July 12, 2003 I had the same problem Locating the Fuel filter in my LS400 1990, It is located on the driver's side right in front of the rear wheels underneath the car. You will need to lay on your back and look up. It sits behind a protective piece of metal. You need to remove it to replace the filter. You can pick up a fuel filter for about 15 bucks at any autozone. Make sure if you do the job yourself, have the fuel tank 99.9% empty, and do not forget to remove the gas cap to relieve the pressure. I bought my LS about a month ago, when I did the Fuel Filter I noticed that it was the original one Quote Link to comment Share on other sites More sharing options...
thewzdoc Posted July 17, 2003 Author Share Posted July 17, 2003 Thank! I had given up hope that anyone knew where this thing was! A friend of mine was searching online for me and found this answer, I told him I had asked the question (he didn't know my user name online!). Thank you again mig25. Now I can change this this weekend! Quote Link to comment Share on other sites More sharing options...
VMF Posted July 17, 2003 Share Posted July 17, 2003 i prefere denso filters, they are OEM filters for lexus. dont forget to jack the car up, its more convenient this way. Quote Link to comment Share on other sites More sharing options...
pwk Posted November 3, 2007 Share Posted November 3, 2007 If you loosen the nut on the front of the filter (the side away from the fuel tank) and fuel flows out freely even with some pressure, would this indicate the filter is ok and the pump pressuring the system sufficiently? This is for a 94 SC400. Quote Link to comment Share on other sites More sharing options...
Thermactor Posted November 3, 2007 Share Posted November 3, 2007 I had the same problem Locating the Fuel filter in my LS400 1990, It is located on the driver's side right in front of the rear wheels underneath the car. You will need to lay on your back and look up. It sits behind a protective piece of metal. You need to remove it to replace the filter. You can pick up a fuel filter for about 15 bucks at any autozone. Make sure if you do the job yourself, have the fuel tank 99.9% empty, and do not forget to remove the gas cap to relieve the pressure. I bought my LS about a month ago, when I did the Fuel Filter I noticed that it was the original one That's an F-15 Eagle, not a MiG-25! Lies! Anyway, go with a genuine Toyota filter. It's the best. Quote Link to comment Share on other sites More sharing options...
