marwankw Posted July 23, 2005 Share Posted July 23, 2005 Hi, I have a 1998 LS400, when I open the reservoir cap I find the P.S. fluid bubbling and in around 20 sec. it overflows and makes the surrounding messy. Any idea why? Steering is not hard and no leaks Quote Link to comment Share on other sites More sharing options...
GRAND_LS 4 Posted July 25, 2005 Share Posted July 25, 2005 Hi,I have a 1998 LS400, when I open the reservoir cap I find the P.S. fluid bubbling and in around 20 sec. it overflows and makes the surrounding messy. Any idea why? Steering is not hard and no leaks ← Maybe you have air in the system? It shouldnt overflow, no matter what. When it does this, does it keep coming out, or do you stop it then? Quote Link to comment Share on other sites More sharing options...
marwankw Posted July 25, 2005 Author Share Posted July 25, 2005 Hi,I have a 1998 LS400, when I open the reservoir cap I find the P.S. fluid bubbling and in around 20 sec. it overflows and makes the surrounding messy. Any idea why? Steering is not hard and no leaks ← Maybe you have air in the system? It shouldnt overflow, no matter what. When it does this, does it keep coming out, or do you stop it then? Ah i don't know, have to try this i usually close the reservoir cap to avoid further mess. Quote Link to comment Share on other sites More sharing options...
chubyball Posted July 25, 2005 Share Posted July 25, 2005 Check your fluid status, it it's need more then add more. But leave your cap open over night to let all air out. Quote Link to comment Share on other sites More sharing options...
GRAND_LS 4 Posted July 25, 2005 Share Posted July 25, 2005 Check your fluid status, it it's need more then add more. But leave your cap open over night to let all air out. ← I think you need to turn your wheels from side to side to get all the air out. Quote Link to comment Share on other sites More sharing options...
sha4000 Posted July 25, 2005 Share Posted July 25, 2005 add more fluid then get in your car and turn the steering wheel all the way left and hold it for a couple of seconds then turn it all the way right and hold for a couple of seconds repeat this process several times and all of the air should be out of the system Quote Link to comment Share on other sites More sharing options...
marwankw Posted August 25, 2005 Author Share Posted August 25, 2005 I finally had to replace the PS pump with the reservoir tank and the small hose between them. total cost was $490 Quote Link to comment Share on other sites More sharing options...
AzHotLS Posted August 26, 2005 Share Posted August 26, 2005 Did you do it yourself or have it done at a shop? Quote Link to comment Share on other sites More sharing options...
marwankw Posted August 26, 2005 Author Share Posted August 26, 2005 Did you do it yourself or have it done at a shop? ← At a private shop with original parts, and $50 was the labor charge. Quote Link to comment Share on other sites More sharing options...
ko90ls Posted August 27, 2005 Share Posted August 27, 2005 watch out when you open that cap! ps fluid can KILL electrical components (alternator, maybe oxygen sensor) i'd use a plastic bag to cover the ps unit just in case! good luck! Quote Link to comment Share on other sites More sharing options...
SKperformance Posted August 28, 2005 Share Posted August 28, 2005 A consistent leak of PS fluid can cause issue but a quick spill is no problem unlike the older 4.0l v8's. Air in the PS system would not be a problem as it is not sealed and circulates the fluid to the reservoir to release air if accumulated. I would have suspected a dirty screen /filter causing the backup. Quote Link to comment Share on other sites More sharing options...
