Anovice Posted July 6, 2005 Share Posted July 6, 2005 My driver side rear break light is out. I believe there are two bulbs and the one at the bottom left as you are facing the rear of the car is the one that is out. I opened the trunk un-snapped the plastic piece and peeled back the carpet. However, for the life of me I cannot figure out which nuts I needs to remove to gain access to the bulb. Does someone have a diagram that would help me? If not, I would greatly appreciate an explaination to how many of these nuts need to be removed and any other details. Thanks much. Quote Link to comment Share on other sites More sharing options...
Toysrme Posted July 6, 2005 Share Posted July 6, 2005 No diagram, but I changed every bulb in my tails a few months back. I remember there being 4-6 10mm nuts you must remove. When you get those off, just pop the entire light assembly out. Quote Link to comment Share on other sites More sharing options...
Anovice Posted July 7, 2005 Author Share Posted July 7, 2005 Thanks much. When I get the 4-6 nuts off, does the light assembly come out from inside the trunk or outside the car? No diagram, but I changed every bulb in my tails a few months back.I remember there being 4-6 10mm nuts you must remove. When you get those off, just pop the entire light assembly out. ← Quote Link to comment Share on other sites More sharing options...
Toysrme Posted July 7, 2005 Share Posted July 7, 2005 The entire assembly pushes out the back of the car. Quote Link to comment Share on other sites More sharing options...
SnesleyWipes Posted July 7, 2005 Share Posted July 7, 2005 Thanks much. When I get the 4-6 nuts off, does the light assembly come out from inside the trunk or outside the car?No diagram, but I changed every bulb in my tails a few months back.I remember there being 4-6 10mm nuts you must remove. When you get those off, just pop the entire light assembly out. ← ← Ya, and you also need to get a 10mm socket that is extra long for a couple of them if I remember correctly. Quote Link to comment Share on other sites More sharing options...
creamyy Posted July 7, 2005 Share Posted July 7, 2005 There's a tutorial here. Not sure if it's the same for a '92, but it helped me out a lot. Quote Link to comment Share on other sites More sharing options...
