New Pics
Hey SK,
Was just looking at your machine again.. I am wondering how you get your front lights looking so sparkely white and clean.. how did you do it, and what chems did you use?
And another thing.. why no badges?
:ph34r: Chris :ph34r:
the get your lights clean you need to use a rubbing compound.. Here we use T-Cut.. it supposed to take out minor scratches from paintwork as it takes a very very small amount of paint off.
use this on yor headlights and keep rubbing... clean off and be suprised!
the lights aer just normally like that i keep them clean
but i have the 94 version not the 95-96 which have a different plastic that does tend to yellow
there is a product i got from meguires called scratch x it seems to work well and is made for plastics and glass that are clear
i wanted a clean look so i removed all the badges 2 years ago and filled the holes
the kit is hand made using a trd for 97-99 camry as a base for the style and tehn remoulded
that grille is a labour of love i hand built it in abuot 7 hours
of forming sheet metal and some bondo to smooth the edges
the lower lip when made will have the same style of tip to it as well
then i just place a black grille behind it and it was done
i am going to restyle it a bit though and smooth the top edge of the tip off
to give it a smoother look
Sharad
I am creating galleries to hold pictures from these sort of shows - so we can have them nicely organised and easy to find when trying to get people to go next year! :D
do you want me to create one for this show, so you can upload all the pictures to it?
if so - what was the show called?
that sounds like a much better idea
it was called "the darknight nationals "
yah most pics are nice to look at but don't need to be lumped in there with other ES's
its ok actually Sharad - I'll move them all over - then change the links in these posts.
will be easier this way round ;)
  • 3 weeks later...
