I just went to check my car and I got a "Code 21:Oxygen Sensor Signal or Circuit fault". Which Oxygen sensor is it on my 2000 RX300 with 1MZ-FE (3.0 c.c V-6) engine?
that is the HVAC system code for a solar sensor not eh engine computer code.
Go and read the general maintance section for more details
i'm not using an OBDII computer here. just a general Rennacs code reader. and it says exactly,
' EFI Fault Code Screen: '
' 21: Oxygen Sensor Signal Or Circuit '
' Last Fault Code In Memory '
change both banks oxygen sensor with O.E.M parts 89467-48011, and it still does not make any difference. what a waste of money. wonder if there is anything wrong with my ecu?
12
RPM Signal
13
RPM Signal
14
Ignition Signal
15
Ignition Signal
16
Electronically Controlled Transmission Control Signal
17
CMP No. 1
18
CMP No. 2
21
Main O2S & Heater Signal
22
ECT Sensor Signal
24
IAT Sensor Signal
25
Air–Fuel Ratio Lean Malfunction
26
Air–Fuel Ratio Rich Malfunction
27
Sub O2S Signal
28
Main O2S
29
Sub O2S
31 & 32
Air Flow Meter Signal
35
HAC/Barometric Pressure Sensor Signal
41
TP Sensor Signal
42
VSS Signal
43
Starter Signal
47
Sub TP Sensor
48
Secondary Injection System Malfunction
51
Switch Condition Signal
52
KS Signal
53
Knock Control Signal
55
KS Signal
70
EGR System Malfunction
71
78
Fuel Pump Control
:wacko: so what are you trying to tell me here DCFISH?
Misunderstood your topic , My bad. :unsure:
