joeypeep Posted June 25, 2005 Posted June 25, 2005 Does anyone know how to lock the KEY in the GS on purpose?? I park my car a parking lot that closes early. In my old car, they would lock the key and I would have an extra one to open the door. On the GS, you can seperate the actual metal key, so you could unlock the door with that....the problem is I cannot get the car to stay locked with the KEY inside - it keeps unlocking. The book says if you keep the key in the Glove Box, the car will not unlock, but it does. Anybody have any ideas?? Thanks
lexus411 Posted June 25, 2005 Posted June 25, 2005 it wont lock in the trunk. It will beep as you close it . Probably would have to disable smart key access. Button is under the dash by steering wheel. Then use the metal key to open.
joeypeep Posted June 25, 2005 Author Posted June 25, 2005 it wont lock in the trunk. It will beep as you close it . Probably would have to disable smart key access. Button is under the dash by steering wheel. Then use the metal key to open. ← what about putting it in an ELECTROMAGNETIC bag (like the one that comes with the toll booth passes)
joeypeep Posted June 27, 2005 Author Posted June 27, 2005 Lock it in the gas cap compartment Win ← I cannot get it to fit in there and shut the gas door....
SKperformance Posted June 27, 2005 Posted June 27, 2005 can't you get it in the cap if you use the wallet key and its case can stay in the car?
Win Lowe Posted June 27, 2005 Posted June 27, 2005 no wallet keys on the 06 GS ← OK Swap my 96 for your 06 I think I can live with that key problem :) Win
SKperformance Posted June 28, 2005 Posted June 28, 2005 I just keep coming up with all the stupid answers that don't work. Aren't their special gas caps that hold keys with a numerical lock to keep a spare key incase of lockout.
TurboGS300 Posted June 28, 2005 Posted June 28, 2005 I just keep coming up with all the stupid answers that don't work.Aren't their special gas caps that hold keys with a numerical lock to keep a spare key incase of lockout. ← Here ya go, the music is annoying :D GAS CAP
SKperformance Posted June 28, 2005 Posted June 28, 2005 OMG I would rather be locked out than listen to that music. Maybe it would be a better theft detterant than a siren wailing at 2 AM
THE ONE Posted June 29, 2005 Posted June 29, 2005 no wallet keys on the 06 GS ← OK Swap my 96 for your 06 I think I can live with that key problem :) Win ← NOW!!! THAT IS A GOOD ONE!!!
blaqman Posted September 23, 2005 Posted September 23, 2005 Does anyone know how to lock the KEY in the GS on purpose??I park my car a parking lot that closes early. In my old car, they would lock the key and I would have an extra one to open the door. On the GS, you can seperate the actual metal key, so you could unlock the door with that....the problem is I cannot get the car to stay locked with the KEY inside - it keeps unlocking. The book says if you keep the key in the Glove Box, the car will not unlock, but it does. Anybody have any ideas?? Thanks ← Okay I got a good one. If you have a sunroof ahy dont you have them lock the car and drop the key through a small opening in the sunroof but instead of just dropping it in the car and making it all obvious tell em put it in mcdonalds bag or somethin. How'd I do?
joey8675 Posted September 23, 2005 Posted September 23, 2005 I actually got a method that works - I guess I should have posted it. I got a little bag (like the one an ezpass comes in) and lined it with NUMEROUS layers of foil. Then, once you put the key in the BAG the sensors stop working. (The method suggested of wrapping it in foil also worked, but this is easier for them to handle)
