Black Lex Posted June 18, 2005 Posted June 18, 2005 Can I use unoxygenated premium gas. On the gas pump it says for collectable cars ,boats , small engines, only ? Octane is 92
Lexusfreak Posted June 18, 2005 Posted June 18, 2005 What brand of gas is it? I would stick with just the usual unleaded fuel personally.......the LS is not a collectable car just yet. ;)
Black Lex Posted June 18, 2005 Author Posted June 18, 2005 What brand of gas is it? I would stick with just the usual unleaded fuel personally.......the LS is not a collectable car just yet. ;) ← British petrolium (BP) seems like every other premium is only 91 oct
lovlex Posted June 19, 2005 Posted June 19, 2005 the car should only call for 91. where i live, there is 89 then 93 so i'm stuck with 93
VBdenny Posted June 20, 2005 Posted June 20, 2005 Oxygenated fuel is used to reduce emissions in smoggy areas. While it does reduce emissions, it uses more gas and hurts performance,
Black Lex Posted June 21, 2005 Author Posted June 21, 2005 Oxygenated fuel is used to reduce emissions in smoggy areas. While it does reduce emissions, it uses more gas and hurts performance, ← Is oxygenated fuel another name for ethenol ? All unleaded gas has ethenol does'nt it? Is the only reason why they have stated on the pump collectable ,boat,small engines ONLY Is so everybody won't use unoxygenated gas and thus increase emissions? Emissions aside , is unoxygenated the best fuel for my 94 LS 400 performance ? Will it hurt my LS ?
spiller91ls Posted June 21, 2005 Posted June 21, 2005 yes you can us unoxygenated fuel, the bad thing about oxygentaed fuel is it attacks seals, and hoses that arn't made to handle the fuel.
SRK Posted June 21, 2005 Posted June 21, 2005 Oxygenated fuel is perfectly fine for your Lexus. The fuel economy reduction is very small, and the reduction in carbon monoxide is significant. Ethanol is one of the ingredients used to oxygenate fuel, MTBE is the other. Both carry extra oxygen atoms on the hydrocarbon molecule. This promotes cleaner burning, especially in the winter-time, when oxygenates are used mostly. The use of oxygenates also improves the octane rating of the fuel, and in the mid eighties MTBE was used to compensate for the reduction in octane caused by the elimination of tetraethyl lead. There is some thought that older carburetors may be susceptible to the ethanol, in that alcohol will react with the old neoprene diaphragms and such that those fuel systems use. There is no component in a modern injected engine that will be affected by oxygenated fuel additives. Oxygenates REDUCE emissions, so use it when you can.
Black Lex Posted June 22, 2005 Author Posted June 22, 2005 Oxygenated fuel is perfectly fine for your Lexus. The fuel economy reduction is very small, and the reduction in carbon monoxide is significant. Ethanol is one of the ingredients used to oxygenate fuel, MTBE is the other. Both carry extra oxygen atoms on the hydrocarbon molecule. This promotes cleaner burning, especially in the winter-time, when oxygenates are used mostly. The use of oxygenates also improves the octane rating of the fuel, and in the mid eighties MTBE was used to compensate for the reduction in octane caused by the elimination of tetraethyl lead.There is some thought that older carburetors may be susceptible to the ethanol, in that alcohol will react with the old neoprene diaphragms and such that those fuel systems use. There is no component in a modern injected engine that will be affected by oxygenated fuel additives. Oxygenates REDUCE emissions, so use it when you can. ← I'm not sure but it seems as if everybody is confusing oxygenated gas with unoxygenated gas. I asked if unoxygenated gas was safe for my car because that is the gas that at the pump says boats,collectables, small engines, etc. ONLY could someone please clarify? sorry for the misunderstanding
monarch Posted June 22, 2005 Posted June 22, 2005 Your owners manual says gasoline containing up to 10% ethanol can be used as well as gasoline containing no alcohol or MTBE. So you're OK using either fuel. As SRK pointed out, oxygenates like 10% ethanol reduce emissions which means your emission system components say cleaner, longer, which in turn helps maintain optimum engine power and drivability. The reason the pump says "for boats,collectables, small engines, etc. ONLY" is because the government regulators want the owners who own cars that can use oxygenated gasoline to use it to reduce air pollution.
Black Lex Posted June 24, 2005 Author Posted June 24, 2005 Very good I'm clear on this now Thanks everybody ( Trying to be a good member of human race . sticking with oxygenated)
waf102 Posted April 18, 2006 Posted April 18, 2006 Oxygenated fuel is perfectly fine for your Lexus. The fuel economy reduction is very small, and the reduction in carbon monoxide is significant. Ethanol is one of the ingredients used to oxygenate fuel, MTBE is the other. Both carry extra oxygen atoms on the hydrocarbon molecule. This promotes cleaner burning, especially in the winter-time, when oxygenates are used mostly. The use of oxygenates also improves the octane rating of the fuel, and in the mid eighties MTBE was used to compensate for the reduction in octane caused by the elimination of tetraethyl lead. There is some thought that older carburetors may be susceptible to the ethanol, in that alcohol will react with the old neoprene diaphragms and such that those fuel systems use. There is no component in a modern injected engine that will be affected by oxygenated fuel additives. Oxygenates REDUCE emissions, so use it when you can. Here is some interesting info... "MTBE has been used in U.S. gasoline at low levels since 1979 to replace tetra-ethyl lead to increase its octane rating and help prevent engine knocking. Since 1992, MTBE has been used at higher concentrations in some gasoline to fulfill the oxygenate requirements set by Congress in Clean Air Act amendments; however, since 1999, in California and other locations MBTE has begun to be phased out because of its health risk related to widespread groundwater contamination (California Air Resources Board, 2004). The Energy Policy Act of 2005 drops the federal requirement for oxygen content in reformulated gasoline [1]. "Oxygen helps gasoline burn more completely, reducing harmful tailpipe emissions from pre-1984 motor vehicles. In more modern vehicles, the emissions reduction is negligible. In one respect, the oxygen dilutes or displaces gasoline components such as aromatics (e.g. benzene) and sulfur. In another, oxygen optimizes the oxidation during combustion. Most refiners have chosen to use MTBE over other oxygenates primarily for its blending characteristics and for economic reasons." ...Well, from the way I read it, oxygenates (e.g. MTBE, Ethanol) may have little effect on our 'Lexi'...in other words - they run clean w/o it. Anyone out there with a chemistry/fuel science backround??? Looking at the $$$ of crude oil, we all need to get educated fast. -B
