Motor Oil
I had a 93 Bonneville SSEi, switched to synthetic at 85k and used it till I traded the car at 155k. Never a leak, but then again, never any sludging.
If it starts to leak, then switch back. If the oil was changed religiously previous to you owning it, then you shouldn't have any problems.
Make sure the formula that you choose says "for higher mileage engines"
steviej
