LexKid630 Posted May 1, 2005 Share Posted May 1, 2005 will the LS430 gauge cluster needles go out like the previous Ls400's did? Are the 01-03 needles cold cathodes or LED's Thanks Quote Link to comment Share on other sites More sharing options...
SW03ES Posted May 2, 2005 Share Posted May 2, 2005 No, they've changed the way the needles are made. The needles are LED (like they've always been) and the backlighting is cold cathode, the only Lexus to use it. Quote Link to comment Share on other sites More sharing options...
blake918 Posted May 2, 2005 Share Posted May 2, 2005 The needles and cold cathode lighting in my 95LS still gives 110% after 10 years and 254,1xx miles. I'm impressed! B) I think the needle issue was just a first generation deal(across the entire line-up I believe.). ;) Quote Link to comment Share on other sites More sharing options...
SW03ES Posted May 2, 2005 Share Posted May 2, 2005 I believe they changed the structure of the needles in 1995 to alleviate the problem. I've never seen a 95+ with this issue. The problem is that the backing of the needle gets brittle with age and cracks, interrupting the connection in the micro LED chain causing the problem. Quote Link to comment Share on other sites More sharing options...
LexKid630 Posted May 2, 2005 Author Share Posted May 2, 2005 All i do know is that the 90-04 needles ARE COLD CATHODES THEMSELVES. the backlighting is as well. If you were to look at the 95-00 gauges, the needles appear the same. They look EXACTLY the same. No square black with a white line down the center, but more of a cylinder likt the >95 models. I think the 00+ nedles are LED's though b/c they do appear different. http://cgi.ebay.com/ebaymotors/ws/eBayISAP...sspagename=WDVW 30 pics down on the gas gage needle; you can clearly see a cold cathode tube ;) Quote Link to comment Share on other sites More sharing options...
SW03ES Posted May 2, 2005 Share Posted May 2, 2005 I'm not sure where you're getting that but the information I have is that they're a strip of very small LEDs bound together, and thats from someone who rebuilds the needles for a living. I've seen pictures of them taken apart and they are clearly LEDs, my guess is what you're seeing is the cover they're hidden behind. I also know for a fact that the design was changed in 95, hence why you never hear of failures on anything newer than a 95. Quote Link to comment Share on other sites More sharing options...
LexKid630 Posted May 2, 2005 Author Share Posted May 2, 2005 Maybe in 95 they were changed. But all i do know is that the 90-94 are cathodes. you can clearly see than the depth of the neelde is bot enough for SMD/s to fit! They look like mini straws; almost like mini florescent lamps! The sc300/400 and old es300's used the SMD's in their needles. These had the problem i think you're talking about. The circuit breaks half way down by excessive heat, causing them to crack, and no longer work. This is what i thought...? Quote Link to comment Share on other sites More sharing options...
LexKid630 Posted May 2, 2005 Author Share Posted May 2, 2005 These links show the sc and old es needles. The tiny lamps are called surface mount diodes, not exactly LED's. They are light emitting "diodes", but are soo much smaller so given the name surface mount diodes. AKA the same just smaller LOL http://lextech.org/gallery/displayimage.ph...m&cat=5&pos=-70 Here you can see what look like cold cathode tubes in the LS models. http://lextech.org/gallery/displayimage.php?album=4&pos=20 Quote Link to comment Share on other sites More sharing options...
SW03ES Posted May 2, 2005 Share Posted May 2, 2005 I see what you're saying, why then does the older LS have the same needle problem as the older ES models? Quote Link to comment Share on other sites More sharing options...
LexKid630 Posted May 2, 2005 Author Share Posted May 2, 2005 I see what you're saying, why then does the older LS have the same needle problem as the older ES models? ← I don't know if it's the SAME problem, it just has a problem. who knows..... :P Maybe it's that the cathodes just don't last very long! or They used the same kind of connection wire that cracks in both cases? Idk Quote Link to comment Share on other sites More sharing options...
LexKid630 Posted May 2, 2005 Author Share Posted May 2, 2005 i'm pretty sure the LS's problems had something to do with the circuits in the actual clusters themselves. The sc and es's were in the needles themselves. And i'm stillsure that the needles in the LS didn't change until 2001 Quote Link to comment Share on other sites More sharing options...
