malli Posted June 29, 2003 Share Posted June 29, 2003 will appreciate if any one know how to change bulb and get access to harnes for third brake light at rear windshield.of my lexus es 300 ...2003 model.....thanks...mali Quote Link to comment Share on other sites More sharing options...
SKperformance Posted June 29, 2003 Share Posted June 29, 2003 the tutorial section is more for already found ways of doing things i will drop this in the es 300 section might get a better response Quote Link to comment Share on other sites More sharing options...
chillaxin Posted June 29, 2003 Share Posted June 29, 2003 hmmm... never ever thought of getting back there. what color are you planning on changing the bulb too? because if its a 2003, there's no way that the light should've burned out already, right? Quote Link to comment Share on other sites More sharing options...
malli Posted July 10, 2003 Author Share Posted July 10, 2003 I am trying to put brake modulator to third brake light ...I need to get to light housing....dont know how to approach...thanks... Quote Link to comment Share on other sites More sharing options...
malli Posted July 10, 2003 Author Share Posted July 10, 2003 sorry...it is 2002 Model....thanks Quote Link to comment Share on other sites More sharing options...
steviej Posted July 10, 2003 Share Posted July 10, 2003 sit in your back seat facing out the back window. Very carefully pry up the plastic cover that is on the back deck above the light. All the stuff is under there. Becareful not to break the tabs that hold it in. You might have to grasp with 2 hands and gently pull the cover towards you then up. steviej Quote Link to comment Share on other sites More sharing options...
malli Posted July 11, 2003 Author Share Posted July 11, 2003 Thanks Steive.....I tried that..before...was afraid I will break it.....will try again...Is ther a way to get to regular brake lights common wire instead of third brake light......malli Quote Link to comment Share on other sites More sharing options...
steviej Posted July 12, 2003 Share Posted July 12, 2003 yep, open the trunk, there are two removable 3x3 inch panels inside the trunk right behind where the taillights are. On each panel, there are two plastic tabs that push inward and then the panel swings out. Behind these panels are the brake and turn signal bulbs and the wiring. Check it out. steviej Quote Link to comment Share on other sites More sharing options...
malli Posted July 12, 2003 Author Share Posted July 12, 2003 thanks stevie...I saw those panels and light housing...but I want to get to common wire that goes to both rear brake lights...that is where i have to cut and insert brake light modulator......thanks....malli Quote Link to comment Share on other sites More sharing options...
