Just shopping some prices for my 98 ES 300. I want a timing belt, pulleys, hydraulic tensioner, water pump and possibly cam/crank seals. I looked at the advertiser on this site(autopartsmart), but coudn't find oem parts? Anyone know where I could getoem Lexus parts other than the dealer?
Thanks, Tom
Thanks, Tom
http://www.luxurymods.com/
All the timing belt components of your '98 ES300 1MZ-FE V6 will be the same as the '98 Toyota Camry (assuming both are NOT variable valve timing engines) I think the change to variable valve timing occurred in '99, but you need to make sure because there are important timing belt component differences between the VVT and non VVT engines.
Anyway, the best online prices on truly genuine Toyota OEM parts can be found at Bob Bridge Toyota www.1sttoyotaparts.com. Compare and you'll see.
Correction to my last post: I did some comparisons and found irontoad.com's prices are virtually identical to 1sttoyotaparts.com prices.
Darrel Diller
E-Commerce Parts Manager
Sewell Lexus of Dallas
www.lexus-parts.com
6421 Lemmon Avenue
Dallas, TX 75209
(866) 770-3099 ext: 2826
(214) 353-2826
(214) 350-5398 fax
ddiller@sewell.com
