BlurrySC300 Posted March 8, 2005 Share Posted March 8, 2005 OK, here's the deal, at wide open throttle my car has like hiccups. It's like the engine loses power almost completely, but then everything comes back. I want to say its like a fuel cut-off. I called a friend of mine at Lexus of Austin, a fellow tech, (though i'm more of an apprentice) and he thought that the problem could be with the throttle positioning sensor or the fuel pump. Any input from any of you guys would be greatly appreciated. Thanks --Taylor Quote Link to comment Share on other sites More sharing options...
jzz30 Posted March 9, 2005 Share Posted March 9, 2005 fuel pump computer? Quote Link to comment Share on other sites More sharing options...
teelias Posted December 7, 2005 Share Posted December 7, 2005 Did you ever figure out why it was accelerating like that??? Quote Link to comment Share on other sites More sharing options...
Chad in SC Posted August 6, 2006 Share Posted August 6, 2006 I drive a 95 sc400 and I'm experiencing the same problems, does anyone have any idea what could be causing this? i'd like to get it fixed as soon as possible. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted August 6, 2006 Share Posted August 6, 2006 I would have said distributor and cap with wires or plugs being a problem also. Quote Link to comment Share on other sites More sharing options...
AngelsAmongUs Posted August 6, 2006 Share Posted August 6, 2006 I would have said distributor and cap with wires or plugs being a problem also. My 95 SC4 does that too. I have not had the time to diagnose, but could be the above or catalytic converter. Quote Link to comment Share on other sites More sharing options...
LUKE a MANIA Posted August 6, 2006 Share Posted August 6, 2006 you sure it's not your fuel injectors. It could be the TPS but if worse comes to worse i'd do a fuel injector cleaner additive to your gas tank Quote Link to comment Share on other sites More sharing options...
SuperCoupe400 Posted August 7, 2006 Share Posted August 7, 2006 I'm experiencing a similar issue with my '93 SC4, but only at very low speeds (usually at take-off or gentle acceleration in 1st or 2nd gear - never at high speeds). I'm thinking this may have something to due with my altenator - seeing as how it's been leaked on by my PS pump and I haven't gotten in there to replace it yet. Quote Link to comment Share on other sites More sharing options...
AngelsAmongUs Posted August 7, 2006 Share Posted August 7, 2006 I'm experiencing a similar issue with my '93 SC4, but only at very low speeds (usually at take-off or gentle acceleration in 1st or 2nd gear - never at high speeds). I'm thinking this may have something to due with my altenator - seeing as how it's been leaked on by my PS pump and I haven't gotten in there to replace it yet. My hesitation is at low speed also but I never suspected the alt. I think you have something else in addition to alt. Quote Link to comment Share on other sites More sharing options...
SuperCoupe400 Posted August 8, 2006 Share Posted August 8, 2006 My hesitation is at low speed also but I never suspected the alt. I think you have something else in addition to alt. Could be my plugs and wires. THey haven't been changed in the 2-years i've had the car. Quote Link to comment Share on other sites More sharing options...
