914lps Posted February 18, 2005 Share Posted February 18, 2005 I heard that on 91 Lexus cars and many others you can read the trouble or engine codes with out a reader. To do this the story goes, you access the code reader computer connection on the car. Then using jumpers, you jump two if the pins together. The code then reads out though the engine light. It “blinks” the code. The trick is knowing what pins to jump. Jumping the wrong pins and you will really do some damage. Anyone hear of this before? Fact or B.S.? While I’m at it. Anyone know of a code reader that will work on a 91 LS400??? I know a company called Actron makes some in the $30.00 to $80.00 range for GM, Ford, Chevy, but I do not believe the have a Lexus one. With most folks charging at least $50.00 to scan the codes I would love to have one. Oh, and don’t tell me AutoZone will scan it for me. They can’t do cars as old as 91… Quote Link to comment Share on other sites More sharing options...
95LS400Bob Posted February 18, 2005 Share Posted February 18, 2005 It's true. OBD1 it is called. But someone will have to tell you what pins to jump. You count the flashes and that's the code. Someone is sure to have more info. Quote Link to comment Share on other sites More sharing options...
pachocco1 Posted February 18, 2005 Share Posted February 18, 2005 http://www.troublecodes.net/Lexus/ you'll need a paper clip. Quote Link to comment Share on other sites More sharing options...
95LS400Bob Posted February 18, 2005 Share Posted February 18, 2005 That's it. And just a note..1995 was ODBII and requires a reader. Quote Link to comment Share on other sites More sharing options...
lovlex Posted February 18, 2005 Share Posted February 18, 2005 http://www.troublecodes.net/Lexus/ says 96 and later you need the reader???????????? Quote Link to comment Share on other sites More sharing options...
914lps Posted February 18, 2005 Author Share Posted February 18, 2005 I looked at the link also. I beleive it means that if the car is older then 96, like 95 on down, then you do not need the reader. I also looked at the codes. And I'm confused. I paid $50.00 to have my car "scaned" due to a idle trouble. I was told the scan showed that it was a bad idle control valve. But I did not see a code per that link for the idle controle valve. So, is there more to scanning the car (91 LS400) then this or????? Quote Link to comment Share on other sites More sharing options...
95LS400Bob Posted February 19, 2005 Share Posted February 19, 2005 95 and 96 are OBDII and you need the reader. Website is wrong. (4 and back..no reader and follow instructions for jumping and reading there on the website. The website is confusing. I have a 95 and it is OBDII and requires a reader. Quote Link to comment Share on other sites More sharing options...
pachocco1 Posted February 19, 2005 Share Posted February 19, 2005 I hope this helps better than the link I gave. Also, did you try to get the code yourself? What did you get? howtotro.pdf diagnosi.pdf diagnost.pdf matrixch.pdf iscvalve.pdf Quote Link to comment Share on other sites More sharing options...
pacolet Posted August 12, 2006 Share Posted August 12, 2006 Excuse the butt-in...I am trying to read the computer trouble code on my 94 LS400. Can I short two pins, and if so what is the correct procedure? Quote Link to comment Share on other sites More sharing options...
LScott400 Posted August 12, 2006 Share Posted August 12, 2006 Pacolet: Just follow the intructions in the link of post #5 above. The connector location is below. Quote Link to comment Share on other sites More sharing options...
