xxxavier2k Posted January 17, 2005 Posted January 17, 2005 I recently changed my strut inserts to KYB GR2's. I was told b my mechanic however that i also need Strut bumpers to control the rate at which the struts travel. I've searched sites and have found both Strut bumpers/bellows and Strut boots. They both seem to be the same thing but I need to know for sure b4 i order them. It's difficult to return items from St. Kitts to the US. Pict of Strut Boot: No pict of Strut Bumper/Bellow but the ones out here look similar
SKperformance Posted January 17, 2005 Posted January 17, 2005 I didn;t know kyb made the inserts i though they only made full shocks for the 92-96 I think the mechanic is refering to the bump stops which don;t control the travel but stop the shock from exploding by having them fully retracted from a hard bump it basically sits on the sturt rod at the top af the shaft against the upper mount you can use your old bump stops no need to change them as they don;t break never heard of a bellow for a strut
xxxavier2k Posted January 18, 2005 Author Posted January 18, 2005 Thanks for the input guys. BTW KYB does make inserts for the 92-92 as does Tokico. They ran me about US$55 for the fronts.
