Brake Pads
Lee S.
Anyone have the part #'s for OEM front and rear brake pads for a 2000RX?
Also is there a separate shim kit needed?...If so, I need the part # for it to.
I'm looking to go to the Toyota dealer to pick up the parts and want to avoid and Lexus/Toyota confusion if any.
Thanks,
Lee
Okay, The OEM Lexus Brake pad Part #'s are:
Front: 04465-48060
Rear: 04466-33050
Unfortunately these numbers will do you no good at the Toyota Dealer...apparently Lexus and Toyota use 2 different parts numbering systems.
So does anyone know the Toyota part numbers for the front and rear pads on a 2000 RX?
FYI...My Lexus dealer wants $75.00 per side or $150.00 total for the front and rear OEM pads. I can buy the same pads on-line for $45.00 per side ($90.00 for the front and rears). Now, if I knew the exact Toyota part numbers I could stop at the local Toyota dealer and save on the shipping.
Any help is appreciated. Thanks,
Lee
Here is the info you needed 04465-48060 can be replaced by 04465-33230 or 04465-33121 or 04465-33180 Also for the rear 04466-33050 can be replaced with an 04466-32050 or 04466-33040 Of course the pad composite is different but I checked both front and both rear numbers and they match right up and are all 4 good Toyota part numbers. :ph34r: Lexus Ninja Guy
Thanks a bunch lordzatez....this is exactly the info I was looking for.
Appreciate your help.
Lee
  • 10 months later...
Lee
Of those three toyota part numbers, which one matches the Lexus OEM type brake pads for the front?
How about the back?
Thanks
