Jimbo1285 Posted December 6, 2004 Share Posted December 6, 2004 my stock alarm goes off when i remote start my car is there anyway to bypass it??? I had the after market alarm hooked up to the stock alarm. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted December 6, 2004 Share Posted December 6, 2004 get a professional to install it. Quote Link to comment Share on other sites More sharing options...
sergioon20 Posted January 23, 2005 Share Posted January 23, 2005 my stock alarm goes off when i remote start my car is there anyway to bypass it??? I had the after market alarm hooked up to the stock alarm. ← hello james. Im sergio. Im 20 and own my own install shop. there is a wire in i think the pass. kick pannel that is called the factory alarm disarm wire. on ur remote start, there will be a wire that will send a negative pulse to this wire in the car that will shut that fact. alarm off. the place that put it in should have done this. if u have any quest. u can call me @ 216-376-4515 -surge- Quote Link to comment Share on other sites More sharing options...
SCoupe Posted January 24, 2005 Share Posted January 24, 2005 Sergio, Is there a way to get an audible confirmation or a light blink when I activate/de-activate my factory alarm on the '94 SC300? Quote Link to comment Share on other sites More sharing options...
SPORTcoupe300 Posted January 24, 2005 Share Posted January 24, 2005 Yes. =) When you lock/unlock, the alarm sends a +12V pulse to the mechanism in the door. You tap that and connect it to a relay. (Read up on the use of relays first) You can then use the relay to power anything you want. (ie. a small horn or your foglights) Good luck. ~Alan Quote Link to comment Share on other sites More sharing options...
SKperformance Posted January 24, 2005 Share Posted January 24, 2005 I will then chirp after it is installed but it will only be a single chirp either way so you won;t know if it is being armed or disarmed Quote Link to comment Share on other sites More sharing options...
