lex Posted June 6, 2003 Share Posted June 6, 2003 Whats a good product for cleaning carpets? Quote Link to comment Share on other sites More sharing options...
NeiLtYmE Posted June 6, 2003 Share Posted June 6, 2003 yeah actually i was wondering this too.... in my trunk mat... i dad managed to spill something .. and now there are tea stains here im soo mad ... - mad neil Quote Link to comment Share on other sites More sharing options...
SKperformance Posted June 7, 2003 Share Posted June 7, 2003 i stand by any 3m prduct there is they are exellent at research and development pricey for some things but worth every cent clean it then scotch guard it Quote Link to comment Share on other sites More sharing options...
SW03ES Posted June 9, 2003 Share Posted June 9, 2003 Believe it or not, a mixture of woolite and water (6:1) does a great job. This is ScottWax's trick on Autopia, works great I've found. Quote Link to comment Share on other sites More sharing options...
lexuskid Posted August 23, 2004 Share Posted August 23, 2004 when you say woolite, theres only one kind of woolite, right. no special blends or anything? and what should i use, a towel or some sort of brush? ive spilled soda in the front and back that darkened into ugly brown/black patches contrasting with the light carpet color and ive wanted to get rid of that for awhile now. Quote Link to comment Share on other sites More sharing options...
TOGWT Posted August 23, 2004 Share Posted August 23, 2004 ~ One man’s opinion / observations ~ Normal Cleaning: Spray on a 5:1 solution, or stronger dependant upon stain (Distilled water / Woolite) until damp this product may be used on all water safe materials. The cleaning action increases with warm water, agitation and longer dwell time. Completely wipe away dirt/grime with damp cloth until clean, rinsing out clothe as required. Allow to completely dry before use. Or try STAINMASTER Guide to Stain Removal. ~Hope this helps ~ Knowledge unshared is experience wasted justadumbarchitect / so I question everything/ Jon Quote Link to comment Share on other sites More sharing options...
DobieG Posted August 24, 2004 Share Posted August 24, 2004 I haven't tried the Woolite method yet, but a product called Folex works wonders. Quote Link to comment Share on other sites More sharing options...
gage Posted August 25, 2004 Share Posted August 25, 2004 Whats a good product for cleaning carpets? sears sells a product called "capture" that is the best carpet cleaner iv'e ever used.it is a white powder and each grain of it works like a tiny little sponge and absorbs the stain. it has totally removed red wine from my tan house carpets. sprinkle powder on, brush it in the carpet ,wait a while and vacuum.best results on fresh stains but comes with a spray to moisten the area before applying powder. Quote Link to comment Share on other sites More sharing options...
tokmik Posted March 8, 2009 Share Posted March 8, 2009 Whats a good product for cleaning carpets? for a list of carpet cleaners you may visit the link below: Carpet Cleaning Estimate Quote Link to comment Share on other sites More sharing options...
Nick Carberry Posted March 10, 2009 Share Posted March 10, 2009 I'm a big fan of the Adam's Polishes Carpet Cleaner. It's pretty inexpensive, and very effective. It doesn't leave any harsh smells either. Just spray, agitate, then take a damp microfiber and wipe away. From there, vaccum as normal. It's great for all-purpose carpet cleaning, and even for some stains, but I will say it's not that "Power" product that I've seen before. Usually I'll use 303 Spot Remover for stains and stuff like that. Quote Link to comment Share on other sites More sharing options...
mikecost Posted March 12, 2009 Share Posted March 12, 2009 This might be overkill, but I just bought a used '02 ES 300 and I wanted the mats as clean as I could get them. Vacuuming and extraction are just not enough to get down into the fibers. Here's a tip on cleaning extremely dirty, winter stained carpet mats: It goes to an extreme but will remove 100% of dirt and dust from deep in the carpet fibers. My mats were cleaned by a detailer twice with their extraction machine and it didn't do a thing to improve the mats appearance because it only extracts surface dirt. If it's warm outside: hit the mats with a hard spray and the soak the mats in a mild cleaning solution , fibers facing down, in a large shallow tub or a large plastic storage bin. Dirt will release downwords. If it's cold outside: use your indoor work tub or your shower and hot water to clean deep into the carpet fibers. If you have a spray hose, use it like a power washer with hot water to get deep in the fibers. Again soak the mats in a mild solution for a few hours, face down. Let chemical do its job. The concept here is using water to remove 95% of the dirt and using a mild chemical with time to remove the grease or stains. Final cleaning: Use a scrub brush and cleaning solution on the mats, rinse, and hang up in the sun to dry. If there is any thing left after these cleaning and soaking steps, your mats are permanently stained and consider having them replaced. Quote Link to comment Share on other sites More sharing options...
pauljcl Posted March 12, 2009 Share Posted March 12, 2009 This might be overkill, but I just bought a used '02 ES 300 and I wanted the mats as clean as I could get them. Vacuuming and extraction are just not enough to get down into the fibers.Here's a tip on cleaning extremely dirty, winter stained carpet mats: It goes to an extreme but will remove 100% of dirt and dust from deep in the carpet fibers. My mats were cleaned by a detailer twice with their extraction machine and it didn't do a thing to improve the mats appearance because it only extracts surface dirt. If it's warm outside: hit the mats with a hard spray and the soak the mats in a mild cleaning solution , fibers facing down, in a large shallow tub or a large plastic storage bin. Dirt will release downwords. If it's cold outside: use your indoor work tub or your shower and hot water to clean deep into the carpet fibers. If you have a spray hose, use it like a power washer with hot water to get deep in the fibers. Again soak the mats in a mild solution for a few hours, face down. Let chemical do its job. The concept here is using water to remove 95% of the dirt and using a mild chemical with time to remove the grease or stains. Final cleaning: Use a scrub brush and cleaning solution on the mats, rinse, and hang up in the sun to dry. If there is any thing left after these cleaning and soaking steps, your mats are permanently stained and consider having them replaced. I'm with you on this. It was the only method I could use to clean the mats on the RX300 after (... while) winter snow+dirt in Michigan. Also took out coffee stain. [i also used "Scrubbing Bubbles" on them after the first thorough wash]. They came out fine.... Quote Link to comment Share on other sites More sharing options...
SW03ES Posted March 13, 2009 Share Posted March 13, 2009 You can also use a power washer on mats, works really well. The reason detailer's extraction machines don't work is they don't know how to use them. If they have REAL extraction machines they absolutely get more than just surface dirt (the OEM Lexus mats aren't very plush). The proper way to extract carpets is as follows: 1. Vacuum well 2. Presoak mats with carpet cleaning solution and allow to dwell for 15 minutes 3. Agitate mats heavily with a stiff carpet brush (they make attachments for buffers too actually) 4. Rinse/extract mats with HOT water from the extractor Many people try and use the extractor to do the cleaning with the solution, it doesn't work. The cleaning needs to be done manually and the extractor used to suck up what is left over. Quote Link to comment Share on other sites More sharing options...
rickatups Posted March 23, 2009 Share Posted March 23, 2009 I have soaked my mats with a strong concentrated stream from my garden hose outside, plus using a brush and various types of cleaning solutions .... FOLEX has worked well the times I have used it .... My next idea has been to use a pressure washer on my mats ... actually I have this one customer that just never cleans his mats ever ... he just waits for me to do it when he brings his car to me ..... so they are a disaster every time I do his car .... they have been so bad, the pressure washer has definitely come to mind several times. The Lexus mats are so strong, I think this method would be safe to do ... I have been doing some reading and have found an extraction machine that has a water temp of 200 degrees at the nozzle .... the machine costs about $700, however ..... I am still cloaking on that price .... but I just might get one anyway. Heat really makes dirt release. anyways ... just my 2 cents worth of comment on the subject .... Quote Link to comment Share on other sites More sharing options...
SW03ES Posted March 25, 2009 Share Posted March 25, 2009 Pressure washer should be fine... Quote Link to comment Share on other sites More sharing options...
Nick Kollaja Posted August 26, 2015 Share Posted August 26, 2015 Well i don't need the carpet cleaning product as i always call the professional from Carpet Cleaning in Frisco, they took my carpet with them and within a day they clean it andmade it new like. . I am pretty much satisfied with their service. Quote Link to comment Share on other sites More sharing options...
ruby22 Posted January 12, 2018 Share Posted January 12, 2018 Hi Lex, I have used Earth Friendly Products Every Stain & Odor Remover for carpet cleaning. This cleaner is very nice and easy to use. I had a very good experience with this product because I have used this product on my 5 years old carpet which contains so many dirt and stains all over it. Then I used this product on it to remove stains and it gives me very good results. You can also search on-line for the similar products according to your choice and budget. Quote Link to comment Share on other sites More sharing options...
Chill61 Posted May 11, 2018 Share Posted May 11, 2018 Chemical Guys Fabric Clean Carpet & Upholstery Shampoo & Odour Eliminator works for me. Been using it for years. Quote Link to comment Share on other sites More sharing options...
stuartmeaker Posted July 7, 2018 Share Posted July 7, 2018 Regular carpet cleaning from an expert near me do cleaning of carpets so i never used to think of having such products. Quote Link to comment Share on other sites More sharing options...
