coppens1 Posted June 21 Share Posted June 21 Dear Fellow Lexus Owners, I have an 01 Lexus ES300. The drivers side window is malfunctioning in the automatic mode after I had the window regulator replaced. When I click the window control for automatic closing, The window automatically closes and then comes back open, about 6 inches. I have to close the window a little at a time to fully close it. Does anyone else have this problem? What is the solution? Quote Link to comment Share on other sites More sharing options...
RX400h Posted June 22 Share Posted June 22 Quote Let’s explore some potential solutions: Window Motor Retiming: Sometimes, the window motor needs to be retimed after a regulator replacement. To do this, the door panel and regulator may need to be removed, and the motor retimed. Consider taking your car to a dealer or a professional mechanic for this adjustment. Window Motor Reset: Try resetting the window motor by following these steps: Remove the window motor from the regulator. Mark the teeth on the window motor. Plug the motor in and spin it 5-8 times. Reinstall everything and test the window function. Check for Obstructions: Ensure there are no obstructions (such as debris or misaligned tracks) preventing the window from closing fully. Inspect the window tracks and seals for any issues. Inspect the Regulator Installation: Double-check that the window regulator was installed correctly. Verify that all bolts and connections are secure. Quote Link to comment Share on other sites More sharing options...
coppens1 Posted Monday at 05:51 PM Author Share Posted Monday at 05:51 PM Thanks. I will check with the auto electric company that installed the window Regulator. Quote Link to comment Share on other sites More sharing options...
