Hello Guys i own a Lexus GS 300 2001 Facelift.
Everytime when i start the car after it cooled down it starts making squeaking noises for about a minute and stops. It only happens when the car was cold before. For example when i drive and make a stop for 1-3 hours it is not happening.
I searched for the problem but the videos i watched the guys had the lights on my doesn't.
Maybe somone knows how to fix it by myself without buying a new brake masyter cylinder assembly.
I added a video with the noise.
Edited by comandershark
Are you sure it's not coming from the engine bay?
I made another video and it is coming from the cylinder in the back.
Do you have a mechanic's stethoscope? You can get one at Harbor Freight at a low price. It will come in handy to pinpoint the source of the sound.
I had a 98 GS300 FOR 225000 Miles, I went through 3 Master/ABS cylinders, I think there is a subject on using a brake booster from a SC430  Check into that.
  • 10 months later...
I have a 05 gs430 that has the exact same issue. Comes from the master cylinder, pressing the brake a few times usually stops it. Other than that I think when someone did the brakes they just didn’t bleed them correct. Going to get a new cylinder, and bleed the brakes again. Hopefully that works…?
