lexus400 Posted September 29, 2004 Share Posted September 29, 2004 Has anyone had a leak in their trunk that they've figured out ? I've been trying to solve my leak (trunk seal looks like it's brand new). It's running down the inside and into the spare tire well. It rained about 3" last night and had at least that much inside the wheel so it's no small leak. Any ideas ? thanks, Bob Quote Link to comment Share on other sites More sharing options...
99lsguy Posted September 30, 2004 Share Posted September 30, 2004 a shot in the dark........ But maybe your drains from the sunroof are plugged; and the water is backing up and running into the trunk area???????? you can get some bailing wire and run down the drain lines from the sunroof to clear out..... Good Luck! Quote Link to comment Share on other sites More sharing options...
jzz30 Posted September 30, 2004 Share Posted September 30, 2004 my 90 had a leak when it was about 5 years old. everything looked fine but it was the seal that was faulty. Quote Link to comment Share on other sites More sharing options...
lexus400 Posted September 30, 2004 Author Share Posted September 30, 2004 thanks guys, I'll check the sunroof and get a new trunk seal as well. Quote Link to comment Share on other sites More sharing options...
ylekiot1 Posted October 3, 2004 Share Posted October 3, 2004 Don't know what year you have but mine is a 90 and I had the same issue. The drain pipe form the power antenna is SUPPOSED to run down to the lower drain below it. I found that the pipe had come out of the drain and was running water into the lower left trunk portion. Once that got full it would run into the tire compartment in the center. Take out the floor panel and the left side panel ( you will have to remove the screws around the tool box)(check the right too if the left isnt having a problem) along with the floor plastic side inserts. Hope that fixes it for you. Quote Link to comment Share on other sites More sharing options...
jzz30 Posted October 3, 2004 Share Posted October 3, 2004 oh yea as a result of my leaky seal my spare rim got all corroded and white scaly stuff on it. so fix it as soon as possible ;) Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted October 3, 2004 Share Posted October 3, 2004 Gee ylekiot1 (Toby), I should have been bringing the old LS to you for service all those years before I sold it to you - except you might have been in grade school or jr. high when I bought it in 1990. Guys, when "ylekiot1" speaks, you might want to listen to him. He has found solutions to several nagging problems on that 90 LS that neither dealer or independent repair shops could figure out. Toby, should I bring my 2000 LS to you for its next service? ;) Jim Quote Link to comment Share on other sites More sharing options...
99lsguy Posted October 3, 2004 Share Posted October 3, 2004 Gee ylekiot1 (Toby),I should have been bringing the old LS to you for service all those years before I sold it to you - except you might have been in grade school or jr. high when I bought it in 1990. Guys, when "ylekiot1" speaks, you might want to listen to him. He has found solutions to several nagging problems on that 90 LS that neither dealer or independent repair shops could figure out. Toby, should I bring my 2000 LS to you for its next service? ;) Jim Ahh, That makes sense!! Jim, since our do not have a "antenna" - I didn't think about that possiblity (forgot it was on older models.....) Quote Link to comment Share on other sites More sharing options...
