I have a 92 ES and I want more power! I was wondering if I was to get an amp from another model and/or year, if it would be better than getting a whoel new and different amp (different brand).
Would an amp from an LS be good?
I have also heard that the whole system is put together so that everything sounds perfect. Does this mean that if I do get a different amp that the system won't sound good?
What is the output to each channel from a stock 92 ES Pioneer amp?
you are right the pioneer system is tuned to work with each speaker
very well
i first changed my speakers and found a drastic difference in volume level decrease
as the stock ones are very efficient
but not presice
the stock amps are very low on power but are mated to work with the system as a whole
i also replaced the amp and re ran all the speaker wires to my trunk
for the new amp
and got a drasctic improvement in sound
then once i took out the stock head unit finally it got much better
a more cleaner and presice sound reproduction
all changes where done over 6 years with about a year in bettween each stage
getting a more powerful amp would do nothing as the speakers would not be able to handle any more power
since they are rated very low
for a low power amp just to be effiecient
the stock amp i am not sure on output but it isn't worth finding out as it isn't a variable that can be taking into account to add to any other system
to use a new amp but stock deck
there are cheap line level convertors which take speaker outputts and turn them into rca outputs
but i find them to sound awful
i spent a few hundred on some crystal line line level convertors
which where much more cleaner sounding and made the speaker level out put as close to an rca output as possible with the use of more than just a variable resistor
good luck
SK-
So do you think the best thing to do in order to get better output would be getting a new HU? If so, which one do you recommend? I would probably get one that reads mp3s.
no the head cannot work with the stock amp
so it has to be last
leave the system alone and add a box if you want more bass
for clarity the whole systme has to go
remeber everything is tuned for itself
take any part out and it will drop in volume
if you want a system to pound so everyone will look at the car :lol:
just add a bandpass in the trunk and an amp
the cheapest and simplest
i'd rip the the whole lot out and get shot of it.
i paid £800 for the whole set up (around $1300) and got some nice kit for this
sound is brilliant. The old system was slung in the trash! best place too
Seriously? Is there a market for the stock tape deck and speakers I just took out to put in my new sound system? (93 es300)
-KMan
I replaced my stock HU with a pioneer mp3/cd player and it sounds great, the bass kicks alot harder in the front than it did with the stock speakers...sounds almost as good as my old car did with 2 pioneer 10" subs with 400 watt amp pushin.
